turbo needed
Old May 31, 2010 | 09:28 AM
Mike F250's Avatar
Mike F250
turbo needed
SO, towing my 5th wheel I noticed that the EGT's were higher than normal. Boost was low. I pulled the intake and found that the compressor wheel was contacting the housing. There is between 1/4 and 1/2 inch end play and side to side play is there too. I don't know if I can rebuild this one or not. Going to the shop to pull it now. If I can rebuild I'm going that route. But, just in case, anyone have anything from stock to an upgrade they would like to sell?
I just need a towing machine, not a race car. I'd really like to not use the WW. Rather have the ATS housing.
Old May 31, 2010 | 03:59 PM
Mike F250's Avatar
Mike F250
Got the turbo apart. The end play allowed the WW to contact the housing. Looking through the parts, what should be in place to minimize end play?
Old May 31, 2010 | 04:06 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
How bad did it contact the housing? Any pics? Depending on damage you might be able to just rebuild. Then again, if you are going with a ported housing and rebuild ect you might as well start looking for a 38R almost.
Old May 31, 2010 | 04:07 PM
joeyd61's Avatar
joeyd61
Sorry to hear that........if needed i have a stocker off my 03 i will sell
Old May 31, 2010 | 05:59 PM
60RatRod's Avatar
60RatRod
Give me a week and I should have a good stock wheel. Just ordered my WW today.
Old May 31, 2010 | 06:00 PM
jkidd_39's Avatar
jkidd_39
I got a stock unit in my shop if you need it
Old Jun 1, 2010 | 12:24 PM
Mike F250's Avatar
Mike F250
Thanks to everyone for the responses!!! I have a turbo on the way. I'll post a few pics of the damage here in a few days to see if it is rebuildable. I know the WW is trashed. The turbine wheel was rubbing against the oil housing? So that may be toast too.
Old Jun 1, 2010 | 12:26 PM
wolfrace's Avatar
wolfrace
You like apples?
I don't have a turbo, but have a stock compressor wheel if you need it.............
Old Jun 1, 2010 | 12:35 PM
Mike F250's Avatar
Mike F250
Thanks fro the offer. If the turbo is salvageable I will need a wheel. I'll let you know when I post pics and get input.
With everything out of the way I went ahead and spent the 50 cents under the valve covers and re-torqued everything.
I plan to gut the EBPV and remove the flap in the exhaust housing too based on this thread.
https://www.ford-trucks.com/forums/8...d-my-ebpv.html
Got the AIH removal pug on the way too.
Old Jun 4, 2010 | 09:36 AM
Mike F250's Avatar
Mike F250
pics added
got another turbo (thanks Joey) and a turbo rebuild kit (thanks Clay). Once I got the turbo apart it was obvious that it didn't need rebuilding but I was already in there...
If the links work, here's a few pics. The thrust bearing is way gone. What would make that happen on a truck with only 120k? I have done regular oil changes.
The bearing cover is worn and cracked, the wheel is a few ounces lighter
Old Jun 4, 2010 | 04:58 PM
joeyd61's Avatar
joeyd61
you are welcome Mike..Hope all works out for you
