40 Pickup Restoration
Old May 31, 2010 | 07:10 AM
HD Rider's Avatar
HD Rider
I have a 40 pickup that was given to me by my grandfather. The engine runs great, it was a NOS short block that was installed about 20 years ago.
I am wondering about updating the distributor to a crab style instead of the drivers helmet to help keep it from getting wet.
Where can I get trans parts? It slips out of second gear so bad it's almost unuseable.
Is there a fix for the rear hub bearings? The rollers in the hubs look good but where they run on the axle tube is pretty worn and starting to pit.
Thanks for any help
Old Jun 3, 2010 | 03:44 AM
Steve Christensen's Avatar
Steve Christensen
Hi there, from memory the distributor drive on the front of the cam sticks out further on a divers helmet set up, the timing cover is different, divers helmet has 3 bolt mount, crab has 2 bolt mount.Whether you can buy adaptors I don't know, you could try the Ford Flathead V8 forum, Ford Flathead V8 .. 1932 thru 1953 • View forum - Q & A General Discussions
When I rebuilt the engine in my '42 truck it had a crab distributor, but for ease of accessibility I changed to an 8BA timing cover, cam, timing gears, water pumps and modified SBC dist.
As for transmission parts, Sacramento Vintage Ford, Dennis Carpenter etc. Maybe a machine shop could metal spray your worn axle housing.
Good luck, Steve.
Old Jun 3, 2010 | 05:41 AM
HD Rider's Avatar
HD Rider
Good luck, Steve.
Thanks much! I'll check those out.
Big Sky
Oct 29, 2012 05:30 PM
wallz
Jan 19, 2011 11:01 PM
trash
Mar 12, 2010 11:36 PM
tractortug
1983 - 2012 Ranger & B-Series
Feb 16, 2007 09:18 PM
woodbutcher2
1978 - 1996 Big Bronco
Dec 20, 2004 03:41 AM
