Lowering a 51 F3
Old May 31, 2010 | 01:47 AM
pbfmav's Avatar
pbfmav
Lowering a 51 F3
I am trying to decide if i am doing a resto or rat on my newly aquired 51 f3. Anyone know how to lower fairly easy? Im looking for about four inches off asphalt. Any info?
1971 F100 5.9L
1951 F3
1975 Maverick
1990 Bronco II
Old May 31, 2010 | 02:15 AM
Julies Cool F1's Avatar
Julies Cool F1
Yeah, take the tires off!
Old May 31, 2010 | 04:29 AM
Daytona F1's Avatar
Daytona F1
4-inches will work just fine as long as you only drive straight ahead or put little wheels on the front so you don't tear your fenders off.
Old May 31, 2010 | 07:15 AM
twise's Avatar
twise
Not easy but you will need to put the leaf springs in the rear on the bottom of the axle which will need some cutting and welding. My 52 was lowered 9 inches by doing this and removing some of the leafs from the pack. Then up front I installed a 3 inch drop axle and removed some of the leafs and lowered it about 5 inches. None of this is easy though. Search here on this site and use Google.
Old May 31, 2010 | 10:54 AM
pbfmav's Avatar
pbfmav
Well the fenders are long gone. I want to use the stock wheels. I only have the hood for the front as far as sheet goes.
Old May 31, 2010 | 01:43 PM
twise's Avatar
twise
pbfmav I have the front fenders from my 52 available. They need some metal welded back in. I was going to repair them but then stumbled across some better fenders. If interested in them message me and we can talk about it.
Old May 31, 2010 | 10:45 PM
pbfmav's Avatar
pbfmav
Ty Twise, if you could send me some pics of how you lowered it, that would be great. what am I looking at for the total mod to get it low??? Thanks
1971 F100 5.9L
1951 F3
1975 Maverick
1990 Bronco II
Old Jun 1, 2010 | 09:42 AM
twise's Avatar
twise
PBFMAV Give me a couple of days to get the pics together. I have a bad memory so message me if you don't see it in a few days.
Old Jun 2, 2010 | 09:35 PM
twise's Avatar
twise
To PBFMAV
I did not take photos as I was doing this but here are some pics of the end results. Hope this helps.
Old Jun 2, 2010 | 10:48 PM
pbfmav's Avatar
pbfmav
Thank you very very very much. Where did you get the drop axle? Did it lower front to back fairly evenly?
1971 F100 5.9L
1951 F3
1975 Maverick
1990 Bronco II
Old Jun 3, 2010 | 06:57 AM
twise's Avatar
twise
Classicperform.com CCP in California. It is a 3" drop axle. I also took a few leafs out to get the drop you see here. I have not gotten to drive this truck yet to see how I like the axle combined with the dropped tie rod ends which you will need also. It dropped the front end to where I wanted it and will come down a little more when the engine / tranny goes in. Also I do not have the front shocks installed yet. Good luck with your project.
Old Jul 16, 2010 | 11:22 PM
OPMAN1's Avatar
OPMAN1
Hi guys sorry to hi-jack your thread
I want to lower my 52 M-1 truck as well and want to put in a drop axle
twise----When you installed yours did you have to bend the steering arms down?
Old Sep 18, 2010 | 03:55 PM
rons1948's Avatar
rons1948
Hello, working on 48 f3. does anyone have any quidelines or specific recommendation regarding pulling individual leaf springs to soften ride. i see pictures of bonus built trucks ranging from 'wreckers to pole trucks' some of these front ends are down to two springs. don't know about the rears usually no close ups. the one or two that i have tracked down were sold buy third party for 'a guy that built the truck'.
I wanted to address ride quality first. then later height via bent/ dropped front axel and placing a ford f250 rear end above rear springs with shock set up like Jules Cool F1
Old Sep 18, 2010 | 05:06 PM
lvin4jc's Avatar
lvin4jc
Enjoy - Ford Truck Enthusiasts Forums - Search Results
Old Aug 1, 2021 | 12:10 PM
Old Skuel Bob's Avatar
Old Skuel Bob
F3 Drop Axle Wanted
Hoping someone out there has a drop axle for a 1950 Ford F3.
