4.6 wont idle
Old May 30, 2010 | 07:42 PM
Hammerhead24's Avatar
Hammerhead24
4.6 wont idle
I have a 05 with f-150 stx with the 4.6, 56,000 miles, have been having trouble with the truck running rough then stalling, have had the fuel pump out and had it checked nothing was wrong with it from what my dealer told me, also have changed the fuel pump driver module which was cracked, no change, as long as my foots on the gas it runs fine, stop at a red light or let off real quick it just dies, i have no check engine light or any codes...yet...i think it may be the pump but havent been able to check pressure yet...anyone have suggestions?
Old May 30, 2010 | 09:25 PM
06F150STX's Avatar
06F150STX
Mine was doing the same thing. I cleaned the MAF and cleaned the plentuim.(throttle body) Runs fine now.
Old Jun 1, 2010 | 06:39 PM
SactoJim's Avatar
SactoJim
What did you use to clean?
What did you use to clean the MAF?
Old Jun 1, 2010 | 07:56 PM
jstnromero's Avatar
jstnromero
There is an aerosol spray specifically made for cleaning your Mass Airflow Sensor.
Old Jun 1, 2010 | 10:33 PM
dbtx's Avatar
dbtx
Also sounds like it could be the IAC - Idle Air Control solenoid. Fords have a problem with this blasted thing. Same symptoms on my `99 Expy and it was this. Piece of cake to replace yourself on that truck. I assume it's still easy to change - it looks that way on my `07 150 anyway. On mine, you could whack the IAC with the butt of a screwdriver and it would be ok for a short while.
veni85
Dec 12, 2015 10:57 AM
Denver Nixon
1997 - 2003 F150
Nov 17, 2015 07:20 PM
bjmayberry2
13
Oct 6, 2015 07:42 AM
tfink3
1997 - 2003 F150
Sep 2, 2014 10:08 PM
