Block stampings
Old May 30, 2010 | 07:04 PM
diane143's Avatar
diane143
Block stampings
Had a guy check out my 390 a few weeks ago. He ended up buying a 460 but said in the course of his research he found that some 390's have a 150 stamped backwards on the block and that may be worth more.
Anyone have a pic of where I should be looking for this?
Thanks,
Diane
Old May 30, 2010 | 07:42 PM
Rockstone's Avatar
Rockstone
Post this in the FE engine forum for a better answer. The mirror stamp is actually 105, not 150. Should be able to find it below the deck on driver side.
Old May 30, 2010 | 08:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Like was mentioned it is a reverse "105" casting. Not a stamping.
They aren't really worth more than the standard "352" castings. However, the likelyhood or odds of being able to bore a 105 block to 4.13 is better than a 352 block.
Josh
Old Jun 2, 2010 | 10:01 PM
Fordworth's Avatar
Fordworth
Just so happens the one I just tore down has the mirror 105 casted into it. That's good news since it's already been overbored. So do these blocks have thicker cylinder walls or less core shift or something? Does the 105 indicate anything in particular?
Old Jun 2, 2010 | 10:10 PM
Bullitt390's Avatar
Bullitt390
Maybe 1 in 30 can go to a 4.13 bore or .080 over
Regular "352" 390 blocks are maybe 1 in 40
Josh
Old Jun 2, 2010 | 10:17 PM
Fordworth's Avatar
Fordworth
I'm really just hoping to go to .060, but maybe I'll get lucky and walls will still be a little thicker.
Old Jun 2, 2010 | 10:43 PM
montana_highboy's Avatar
montana_highboy
Drill Bit Test - BumpWiki
Old Jun 2, 2010 | 11:17 PM
Bullitt390's Avatar
Bullitt390
I wouldn't be too worried going .060 over with any 390 blocks after 66 or so.
You can do the drill bit test as Montana suggested to get an idea of what you can do.
You're machine shop should be able to sonic-test the block to see as well.
Josh
Old Jun 2, 2010 | 11:29 PM
Fordworth's Avatar
Fordworth
Yeah, the one in my highboy is .060 over already with a lot of miles and it's starting to show its age. I figure the block is done so I grabbed a freebie from Chasetruck754. I'm not worried about going .060 over on it but it's .040 over now so I hope just another .020 will do it. I'll do the drill bit test tomorrow then its off to the machine shop to have the bores measured and decide wether it's worth storing or not.
