BTS
Old May 29, 2010 | 10:56 PM
gr8scott72's Avatar
gr8scott72
BTS
Well, I've had a little time behind the wheel with the new BTS tranny. Very impressed. It was a great trip and Brian is a great guy. Highly recommend him to anyone that is having any tranny problems. Well worth the money.
Had to take it up there in the Durango as the tranny grenaded itself. I really wanted to just drive up there in the Excursion but oh well.
Looks brand new:
Nice new TC:
Old May 29, 2010 | 11:04 PM
gr8scott72's Avatar
gr8scott72
I bought and installed a new 6.0l tranny cooler at the same time as having this tranny installed. One unexpected thing I noticed is that the tranny temps are actually a little higher now than they were with the stock cooler. So are the water temps. Only thing I can think is that since it's so much bigger, it's not allowing the radiator to dissipate as much heat which in turn also raises the tranny temps as the fluid goes thru the radiator also. The water temp and tranny temps are pretty close.
The bigger cooler is more stable. It doesn't seem to jump up in temp near as quickly as it did before and cools off quicker when not pushing the skinny pedal.
Still no big deal as the temps are right at or below 200° (think it got to 202° max) with a good load behind it (6 yards of top soil and planting mix in a 3,000 lbs dump trailer) driving around town with the water temps at 185° to 195° with outside temps in the mid 80s.
Anyway, just thought I'd share what I've experience with the new tranny. (Calling it a rebuilt tranny doesn't do it justice.)
Old May 31, 2010 | 11:50 PM
kidwagon's Avatar
kidwagon
Sure looks nice! I thought BTS was in California, did you drive all the way to California for a transmission?
Old Jun 1, 2010 | 12:37 AM
Stewart_H's Avatar
Stewart_H
BTS is in Lead Hill, Arkansas.
John Wood is in California. Holtville, CA.
Stewart
Old Jun 1, 2010 | 11:41 PM
EXv10's Avatar
EXv10
Pretty converter.
Old Jun 1, 2010 | 11:46 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by EXv10
Pretty converter.
I guess you've been out of the wrenching biz for longer than I had thought.
That paint job is the tell-tale signature paint scheme of a PI torque converter.
Precision Industries
Stewart
Old Jun 2, 2010 | 06:17 AM
Macmathews's Avatar
Macmathews
More info
Is that still a 4 speed trans ?
Any other details on it ?
Looks Great.. All blasted clean and looking NEW !
Kyle
Old Jun 2, 2010 | 07:50 AM
gr8scott72's Avatar
gr8scott72
Kyle
Still the same. Still operates the same. Just has almost better EVERYTHING. Each of the clutch packs now have 6 clutch discs instead of just 5. The reverse/manual downshift clutch pack now has 7 clutch discs instead of just 5. Many of the parts that were aluminum are now steel. The valve body was completely reworked and shifts GREAT! A transgo shift kit was added. The case was cleaned and then repainted. Many parts that he installed, he has slightly changed like on one part where a large clip goes on the inside lip, it now has more area to attach with.
These are just some of the things that I can remember. I'm sure there are PLENTY of things that I don't remember or don't know.
Another great thing about his trannies is that he puts EVERY upgrade in ALL his trannies. They are all the flat rate of $4300. His explanation was that if you didn't want to pay for one upgraded part, what was he going to put back in there? The old part? It's worn. A new stock Ford part? Costs more and isn't as good. That's why he just upgrades everything that he knows is a weak point. Even if it's something that you might not ever need. I'd say that about 70% of the old parts went in the trash as he pulled them out.
Old Jun 2, 2010 | 07:51 AM
gr8scott72's Avatar
gr8scott72
Stewart
Yep and just that converter is about $1000 by itself.
Old Jun 2, 2010 | 11:09 PM
EXv10's Avatar
EXv10
Stewart
Yep 1970 was the last year of professional wrench bending. I probably wore out more wrenches than what Sears has in their store. Nothing against color coding; it's a great idea. In fact auto trans was my specialty (in the days of the B&M hydros). I was only razzing you (do they still say that?)
Old Jun 3, 2010 | 12:08 AM
Stewart_H's Avatar
Stewart_H
Oh I knew youz was playing, but I was also pretty sure you didn't know it was a PI converter.
Wow, 1970! I knew you'd been retired for awhile Brent, but I woulda never guessed it had been that long!
Stewart
Old Jun 3, 2010 | 10:56 AM
Splash67's Avatar
Splash67
It is cool to see a picture of my competitor’s transmission case. The case that you pictured here was made by JL French and machined by Ford…we made the 5R55N/S and the 4R75, and now we make multiple versions of the new 6R80 transmission cases. The die cast business is cut throat and with Ford being the only non-bankrupt domestic auto company they are VERY particular about the quality of the parts they order. They treat their vendors very poorly, but it is only because they are striving to make a zero defect vehicle. The same reason they treat us poorly is the same reason that I purchased a ford for the first time in almost 20 years…
Old Jun 3, 2010 | 11:11 AM
EXv10's Avatar
EXv10
Stewart
That wasn't my last job. I was a carpenter, building contractor, and realtor since then (and photographer), I'm 67 now.
gr8scott72
Feb 1, 2017 06:25 AM
gr8scott72
May 30, 2010 12:36 AM
gr8scott72
Jul 26, 2009 09:34 AM
gr8scott72
Jun 30, 2009 01:02 AM
gr8scott72
Dec 6, 2008 08:30 PM
