79 F250 4x4 alt. question
I have a 79 F250 4x4 with a 460. The PO noched the front crossmember to fit the alternator. I want to make this right but cant seem to find a good place or way to mount the alt. Any ideas (pictures would be even better)? Would also like to install a larger alt, say atleast an 80amp.
Here's a pic of the L & L products brackets. here's their link.
Ford Headers, Dodge Headers, Chevy Headers at L&L Products
Always a problem to get around with the 460 swap in a '77.5-'79 f250. When you mount it up high you have to run it off the crank and fan pulleys, not a good deal as you loose belt surface area. I made my mounts and my alt only runs off the crank pulley and the frame is not cut out.
Thanks Phatjack81. I forgot about L&L. Nice stuf but over priced.
I 'll go look for pullies off a A/C 460 and fab up some brackets for the alt
