4x4 problem
Old May 29, 2010 | 03:26 PM
spudgunman's Avatar
spudgunman
4x4 problem
78 250 the transfer case with 2w/4hi/n/4lo
when I lock the hubs and travel forward 4x4 works, when I turn about 3/4 to 1 turn I have the front make this metal bending noise that is horrible sounding
when I am on gravel and turn and drive real slow the rear tires will spin out with the "noise" on the front like with the rotation on the front something will bind and the rear will spin out due to the differental etc
I have a uJoint (the little one in the front knuckle) that looks like it has been in salt water for 100 years and its rusty to all heck.
what is the likely hood this is the cause? what else should I check out to diagnose the 4x4 failure
once the transfer case is in 2x there is no problems with the locked hubs BTW only when power to 4x
Old May 29, 2010 | 04:24 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Possible difference in front/rear gear ratio. The rear is the most likely to have been swapped. Check to see that the ratio matches the door tag. If it's correct, then check the front.
Old May 30, 2010 | 10:56 AM
spudgunman's Avatar
spudgunman
I will check that out, would that still be the issue if 4x4 works in hi and low while not turning the wheels more then 3/4? for instance to test the 4x4 i drove into a ditch and got stuck then drove out with no issues in 4xhi then after that drove home in 4xhi on the pavement with no issues
Old May 30, 2010 | 11:05 AM
mark a.'s Avatar
mark a.
Turn your front wheels all the way in either direction. Reach in and try to turn the axle ujoints by hand. If there is any resistance then you have a bad axle ujoint.
Old May 30, 2010 | 12:11 PM
HillbillyDeluxe81
Ok, wait.... when you say turn..... you mean turning the steering wheel?? I thought you were saying when the wheels turn....as in when you start to drive forward, the truck binds and slips. But you're saying everything is fine when going straight?? The problem only occurs when the steering wheel is turned??
Old May 30, 2010 | 03:44 PM
460/5's Avatar
460/5
Zombie Survivalist
like what kinda horrible metal bindin noise? like a clunk or a tick, or like gears grindin?
Old May 30, 2010 | 05:07 PM
FarmerBill's Avatar
FarmerBill
yeah exactly .. i'm thinking just outer ujoints.. hard to tell. but if there tight and intact in general haha then start thinking pull diff cover. or look inside the plug hole... with flashlight btw its dark in there. My friend had a heap cherokee with fuuuked split outer ujoints and it would click click slide tire... such a pain to push onto the trailer. Maybe park it lift the front tires put tcase in N. and start spinning things by hand... you get it figured out i'm sure of it.
Old May 30, 2010 | 07:39 PM
phatjack81's Avatar
phatjack81
You may have a bad u-joint or a bad lock out but the chirping and binding is from running 4 wheel drive on a hard dry surface and trying to turn. The front axles are trying to turn faster than the rear but the transfer case won't let it, and that can cause drive line breakage. In the mud, snow or gravel road etc. the tires can break loose to unload the pressure.
Old Jun 1, 2010 | 12:25 PM
spudgunman's Avatar
spudgunman
yes its the steering wheel turn that I am referencing
The noise is like a horrible grinding or something hard to describe its loud and nasty
I have only tested on gravel to prevent damage to the drive train
are you saying to do this while the truck is in 4x ? the ujoint is still there so only if I pull it into 2x will it spin
Old Jun 1, 2010 | 02:50 PM
phatjack81's Avatar
phatjack81
The easiest way is to have someone else drive it while you listen to hear where the noise is coming from. To check the u-joint put it 2 hi with the hubs locked and put a pry bar beside the u-joint and through the yoke and try to turn the axle back and forth and see if the u-joint has a lot of play, there shouldn't be any. Could also be a bad lock out too or something as simple as a rock caught up somewhere.
