steering column part needed
Old May 29, 2010 | 01:41 PM
hotrod351's Avatar
hotrod351
i broke the part inside the steering column that the key tumbler moves forward and backwards. it has the rod connected to it that also connects to the switch on the column, any one know where to find it and what its called.
Old May 29, 2010 | 02:13 PM
2stroke rider7's Avatar
2stroke rider7
It is called the ignition switch actuator. You can get it at autozone, it's in the "HELP" section. It is kind of hard to replace if you haven't taken apart the column before but you will learn.
Old May 29, 2010 | 08:16 PM
hotrod351's Avatar
hotrod351
got it at autozone. not that bad putting everything back together, and hey, i dont have any bolts or screws left over.
