98 ranger 02 sensor
Old Oct 19, 2009 | 07:34 PM
bigredball90's Avatar
bigredball90
98 ranger 02 sensor
It says that bank 2 sensor 1, code 0153 02 circuit slow response. Which side is that sensor?
Thanks
Old Oct 19, 2009 | 08:44 PM
Rockledge's Avatar
Rockledge
Bank 2 is the driver's side.
Old Oct 19, 2009 | 09:33 PM
bigredball90
oops forgot sensor 1 would be the one closest to the manifold right?
Old Oct 19, 2009 | 10:09 PM
Rockledge's Avatar
Rockledge
That is correct.
Old Oct 20, 2009 | 07:21 AM
pawpaw's Avatar
pawpaw
P0153 says that the computer is unhappy with the drivers side bank 2 upstream O2 sensor switching speed, that it's slow & lazy & that comes with age, sorta like pawpaw!!!! lol
Anyway if these are the OEM O2 sensors, or they have 100K miles or more on them & you choose to change the bank 2 sensor, also consider changing the bank 1 upstream sensor, so you have a matched pair. The computer would appreciate that!!!!
While your servicing the O2 sensors, be sure to pull the B- battery cable, to wipe the computers memory, so it knows the repair has been done & can begin to rebuild new fuel trim tables, using the new O2 sensors input.
Also be sure to put some high temp nickel anti-sieze compound on the O2 sensors threads.
As a side, you may notice improved mpg with new O2 sensors.
More thoughts for consideration, let us know how it goes.
razors_edge09
May 2, 2015 05:13 PM
JSTJ704
Jul 23, 2014 07:44 PM
MikeRizz
Mar 24, 2010 09:56 AM
