Thick Exhaust Gaskets
Old May 29, 2010 | 09:55 AM
Victor L's Avatar
Victor L
Getting ready to swap in a good 360 into my 69 F100. Both engines had those typical metallic fiber exhaust manifold gaskets, and they were all blown out.
The plan is to go with these good high quality, thick, header gaskets. Do you think that is over kill? Has anybody else had the need to do the same?
Old May 29, 2010 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford did not install exhaust manifold gaskets on any of these trucks, as they never offered them. The only thing Ford installed on FE engines (except 406/427's) were stainless steel heat shields.
If the engine has composition exhaust manifold gaskets, they're prolly made by Victor or Fel-Pro.
Old May 30, 2010 | 09:14 AM
Victor L's Avatar
Victor L
Wow, I never knew exhaust manifold gaskets were not standard.
I want this engine to sound nice and quiet, at least under the hood.
The gaskets at the parts store are designed to eliminate header leaks. They look like they may compress slightly.
Old May 30, 2010 | 04:18 PM
FarmerBill's Avatar
FarmerBill
Maybe it may be a little wrench time but try it with out gaskets they'll fit tighter then with the gasket in the middle can't hurt to try. Guess depends on how true both surfaces are. Wonder why they never came with gaskets .. oh well guess it worked for them back then.
Old May 31, 2010 | 11:15 AM
Victor L's Avatar
Victor L
They probably worked fine when the parts were new, and freshly machined surfaces. Forty years later the manifold sealing surface is rough and rusty, that's the concern with sealing even with standard gaskets.
Old May 31, 2010 | 03:27 PM
NumberDummy
Within five years or so, the manifold sealing surface is rough and rusty, that's the concern with sealing even with standard gaskets.
Fixed it for you.
This is why most of the dealers back then carried Victor exhaust manifold gasket sets in stock.
Exhaust manifold gaskets weren't available from Ford, cuz Ford didn't install or offer them. Only the stainless steel heat shields (C1SZ9448E .. Left & C1SZ9448F .. Right) were installed.
Can y'all hear that in-famous tick, tick, tick? Leaking exhaust manifolds on FE engines have been a problem since the engines were first introduced in 1958.
And...many ppl confused the leaking exhaust manifolds tick tick tick with bad lifters, so they replaced the lifters. When all was said and done, the tick tick tick was still there!
Old May 31, 2010 | 04:01 PM
xstrange's Avatar
xstrange
Bill, is there any special preference of the Victor gaskets over the Fel-Pro gaskets? I see the Fel-Pro's listed at my usual places.
My old 352 has the ticks.....Plus the drivers side manifold has been welded in several places. The welds themselves look pretty good and holding, but I can imagine how uneven the mating surfaces must be. My truck spent 42 years on a farm in central California.....
Old May 31, 2010 | 04:07 PM
NumberDummy
All I know is most dealers around here carried Victor gaskets which were bought from the local parts stores...which may not have carried Fel-Pro gasket sets.
Old May 31, 2010 | 04:19 PM
68horses's Avatar
68horses
Victor L & All,
Check out these manifolds:
Ford F250 Truck Exhaust Manifold at 1AAuto.com
Even though the heading says F250, it's for all F-series. Ive heard good reports on these manifolds and the price is pretty decent.
HTH
Gene
Old Jun 1, 2010 | 01:26 AM
xstrange's Avatar
xstrange
Gene;
Thanks for the link....those manifolds do look reasonably priced, and it at least sounds like they've tried to make them stronger than the originals.
But I'm confused...They only offer the drivers' side manifold for the "68-76" 390 engine, and not for the "65-67" 352 engine. Doesn't the 1967 chassis with the 352 use the same manifold as the '68 390? It visually looks the same. Is there some hidden difference?
Old Jun 1, 2010 | 03:31 AM
NumberDummy
Gene;
As original:
DOTZ9430A (replaced C5TZ9430A) .. Right Exhaust Manifold.
Fits: 1965/67 F100/350 352 / 1968/76 F100/350 360/390.
C5TZ9431A .. Left Exhaust Manifold-Use w/heat riser valve.
Fits: 1965/67 F100/350 352 / 1973/74 F100 360.
C8TZ9431B (replaced C8TZ9431A) .. Left Exhaust Manifold.
Fits: 1968/72 F100/350 360/390 / 1973/74 F100 390 / 1973/74 F250/350 360/390 / 1975/76 F100/350 360/390.
The 1965/67 left exhaust manifold is machined for the heat riser valve. 1968/72's don't use one.
The same left exhaust manifold that was used 1965/67 was also used on 1973/74 F100 360's which use a heat riser valve.
Old Jun 1, 2010 | 01:49 PM
xstrange's Avatar
xstrange
Okay, so the heat riser is the difference. Mine has the heat riser, and it looks to be leaking too. So, I'll probably go with the aftermarket '68-'76 manifold and get rid of the heat riser entirely. Cold weather start up isn't too big a deal here in Burbank.
Thanks for the info!
Old Jun 1, 2010 | 03:55 PM
Danger_Dave's Avatar
Danger_Dave
i have no experience with these but i have been wanting to try them, i have read good things about them on other forums. theyre called remflex exhaust gaskets and they supposedly squish when you torque them.
Johnny Be Cool
17
Apr 3, 2016 10:11 AM
tobyw
Modular V10 (6.8l)
Oct 31, 2013 05:56 PM
windevil pete
Dec 3, 2007 08:58 AM
lifted77f250
Jun 8, 2006 02:57 PM
FalconStng
May 10, 2005 05:39 PM
