Last time i checked there isn't anything different about them besides wheel base and the front part of the cab and back and back half of the frame. The bronco is based of the f150.
The 2wd F150 and 4wd F150 use the same frame. So the axles will bolt right in from the bronco. Using a bronco for a 4wd donor to convert a 2wd F150 to 4wd requires a couple extra considerations. The driveshaft is different, but can be custom made to the correct length. Also the bronco uses a wedge shaped block between the springs and axle, where a 4wd F150 uses a striaght 2" block.
2wd uses a 2.5" wide leaf, and 4wd uses a 3" wide leaf. These can be swapped, but it's not required. Simply getting the spacer blocks and ubolts from a F150 4wd and putting them in place will suffice, though you'll need the rear shocks and chassis to axle brake hose for a 4wd.
Other than those items, it's all pretty much a bolt in swap. Doing the same thing myself, with a bronco as the donor.
