Flooring Suggestions....
Old May 30, 2010 | 04:51 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Can we start another made in China thread?
(...in the Club, of course )
Old May 30, 2010 | 10:00 AM
Nitramjr's Avatar
Nitramjr
I stopped by Lumber Liquidators yesterday and picked up a couple samples - one of them is probably a perfect match but will take it over to Mom's and see which one.
One is priced $1.69 psf and has the padding on it. The other is $1.19 psf but has no padding. Padding, coincidentally, is $0.50 a square foot. Both are stock items at least. I believe both are U.S. made. They both look like they will match the height of the existing floor.
Now I have to decide if I want to pull the existing baseboard off the wall (I think it is glued on since I see NO sign of nails) or install a quarter-round at the base of the baseboard. For $0.89 plf I am thinking of just installing the quarter-round and avoiding all the work of pulling baseboard off - especially since I already painted. Thoughts?
Old May 30, 2010 | 10:07 AM
hanklin's Avatar
hanklin
Ray another option on the 1/4 round is get paint grade and paint it to match the base, alot cheaper and I personally like that look better than wood matching. My .02
Old May 30, 2010 | 10:08 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Definitely just add the shoe moulding.
Prime and paint it first, so you just have to touch up the brad holes where you attach it to the baseboard.
Old May 30, 2010 | 10:14 AM
hanklin's Avatar
hanklin
And dont forget the 6 mil plastic, and when you install that make sure you overlap your seams by at least a foot and then tape with waterproof tape
Old May 30, 2010 | 10:25 AM
Nitramjr's Avatar
Nitramjr
You are right - the quarter-round would look better painted than natural look. And I definitely like the idea of not pulling all the baseboard off. I am going to paint it BEFORE I put the floor down. Dad won't notice (he is legally blind) but I know that if I don't paint it, either my mother or one of my crazy sisters will notice it and I'll never hear the end of it.....
Old May 30, 2010 | 10:32 AM
hanklin's Avatar
hanklin
^^^^smart man
Old May 31, 2010 | 02:21 AM
19fifty4's Avatar
19fifty4
I've put down the laminate myself and have been real happy with it. Using in now in a few rental homes because it's easier to clean than carpet.
It's a floating floor so you can put it down directly over concrete slab. Just make sure to use the poly. Some of the pads they make today have both in them but make sure you use a moisture barrier. I'd pull up the molding, install the floor, and go back withshoe moulding around the exterior. I've used some of the prepainted composite stuff and it goes real fast.
Good luck with your project.
Old Jun 6, 2010 | 10:44 AM
jake00's Avatar
jake00
Bamboo itself might be "green" but there's nothing green about the 5 year old Chinese kids gluing it together with formaldehyde based glues....
Old Jun 7, 2010 | 09:55 PM
Nitramjr's Avatar
Nitramjr
Looked around some more and found an almost perfect match at the Deepo. It's a buck more per square foot but looks a bit nicer AND is U.S. made. As long as Mom gives the go-ahead, I will probably start later in the week. I am kind of dreading this since I have to lug everything up to the seventh floor. Will probably get the folks a fine if I get caught bringing my table saw up in the elevator.
So, a couple last questions.
1. HD sells a padding that supposedly has the moisture barrier in it. Is that any good or should I just go with the separate poly? And what type of tape is "waterproof" to tape the poly at the seams? Also, do I just run it right to the base of the walls?
2. There are a few small holes (maybe 1" across, 1/4" deep) from where the carpet tack strip nails were removed. Should I fill these with floor leveler or will the laminate bridge these safely?
3. Tools? Here is the list of tools I am planning. Since Dad has no tools at all (I got them all, he's legally blind) and since I live 11 miles away, I'd like to bring everything I need. Please add to the list if there is anything I might need....
- Table saw
- Jig saw
- Chop saw
- Speed square
- Tape and laser measure
- Utility knife
- Hammer
- String and chalk-line (for layout)
- Safety glasses
- Ice chest loaded with cheap beer
Any other suggestions?
Thanks
Old Jun 7, 2010 | 11:24 PM
petes79f150's Avatar
petes79f150
The "built in" barrier is fine, no poly required. Just run it up to the walls. Don't worry about the nicks in the concrete from the tack strips.
BEFORE you unload all these boxes, have all your pad laid, they just get in the way. Take a few boxes, unload them, give them a quick once-over, and temporarily loosely lay a few boxes' worth (maybe 1/4 of the room) in the direction you think want it, up against one wall, step back, make a decision, pop a "control" line and rock on. If you've got any help at all, a big help is just having someone un-boxing and laying the stuff out in front of you (besides fetchin' beers ) Just pay attention to your staggers. You'll be surprised how fast it goes once you get in a rhythm.
#1- Don't stress- it ain't rocket science.
#2- Don't drink too many beers.
Pete
Old Jun 7, 2010 | 11:45 PM
Nitramjr's Avatar
Nitramjr
Rocket science I could do. Flooring? We'll see.
Just kidding on the beer thing. I work nights so if I drink it would have to be at six in the morning. Besides, I never mix power tools with alcohol. Fireworks and alcohol, sure. Not power tools.
Thank you, by the way.
Old Jun 8, 2010 | 03:31 AM
  #28
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Good advice.
You'll be fine.
Old Jun 8, 2010 | 01:34 PM
  #29
hanklin's Avatar
hanklin
Ray, to be honest,chalk box is pretty worthless with what you are doing. I would start along the longest wall and go from there. After you have 3 rows laid together the floor go back and drop in your spacers for expansion. The floor as you know floats so it straightens itself out, make sense? I also do all my cuts with a table saw rather than a chop saw because the blade lasts alot longer. The all-in-one pad has a row of tape built in that you pull tab/paper off and exposes sticky stripe which you adhere to previous laid piece of pad. Have fun and no cervezas until finished
Old Jun 8, 2010 | 01:48 PM
  #30
BIGKEN's Avatar
BIGKEN
I didn't see Band Aids on your list.
