4x4 wheels/tires
4x4 wheels/tires
Anyone have any pics of some 4x4 slicks with non-stock wheels and tires? 1965F1004x4's are the only ones I've came across so far. I'm leaning towards some American racing Outlaw's (no holes) or maybe some OEM 92-96 Ford wheels such as these
If someone even had some pics of either wheels on a 2wd that would help! Problably going to run 33x10.50R15's or 33x11.50R15's
Nothing? I'm not contagious, I promise. We are leaning more towards the stock Ford Alcoas at this point, I believe the front track width on the F100 is quite a bit wider than the rear, and I don't like it when the front tires stick halfway out of the fenderwells.
mine has some generic white wagon wheels and 36x14.5 rubber. Only pic uploaded so far is in the sig.
are you looking to see the ride height/style etc of the truck with aftermarket wheels or are you actually looking for rim design?
These trucks are by far the best looking trucks lifted with big tires.
I assumed that type of hood 'action' was a sign of the hinges being "sprung" and
that the necessary cure was to replace the hinge assembly, not just the hinge springs?
If my assumption is true, then replacing just the hinge springs won't fix that.....
BarnieTrk
BarnieTrk
npd23
Jan 9, 2013 03:49 AM
79FORDF1504X4
Nov 27, 2005 10:32 AM
