Need help with simple electrical problem
Old May 28, 2010 | 06:16 AM
Robert6401's Avatar
Robert6401
Exclamation Need help with simple electrical problem
The white ground wire coming from my 7-pin plug on my truck has a small break in the sheath exposing some of the copper. I am thinking this may have something to do with my weak trailer brakes? Can someone tell me how to fix this break in the sheath? Thanks.
Old May 28, 2010 | 10:17 AM
Lady Fitzgerald's Avatar
Lady Fitzgerald
I have no way of being able to say from here whether the open copper is causing your brake problem (other than to say it's possible). If the break is away from the connector, you could just tape the snot out of it. Better, if you can get it onto the wire without cutting it, would be to use a heat shrink sleeve.
If the gap is right by the connector, a small glob of silicone rubber will seal it up. Be sure to check to make sure corrosion hasn't gotten into the connector.
Last edited by Lady Fitzgerald; May 28, 2010 at 10:18 AM. Reason: Senioritis induced spelling error
Old May 28, 2010 | 10:29 AM
Robert6401's Avatar
Robert6401
Thank you. I taped it up real good. We'll have to see how she brakes.
Old May 28, 2010 | 01:13 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I also doubt if this would cause your problem.......I too, have what appears to be weak brakes on my 5er, but when I needed to make an emergency stop, I found out they really weren't so weak. Do you have the Ford TBC? Or an aftermarket?
Old May 28, 2010 | 06:25 PM
TexasRebel's Avatar
TexasRebel
it is the ground wire, correct?
as long as the wire isn't broken, that one doesn't matter if there is insulation around it or not... it is the low potential side.
