At my wits end!@!
Old Feb 5, 2003 | 08:32 PM
BB's Avatar
BB
At my wits end!@!
Oops, maybe I said that too loose.
What I meant is double the rpm's and degrees but don't double the vacuum reading, 20" is 20".
BTW my Sun machine needs new bearings, know where I can get some?
Barry
Old Feb 5, 2003 | 09:01 PM
Mike W's Avatar
Mike W
At my wits end!@!
I have a lathe, I would be happy to make you a set, no charge. Just would need the specs. I still say you don't double the degrees.
Old Feb 5, 2003 | 09:43 PM
BB's Avatar
BB
At my wits end!@!
It has to be Mike, 16 degrees at 4000 rpm is toooo little, and that's the max spec. Distributer degrees and rpm are one-half engine degrees and rpm.
My '72 service specifications book makes a note in the advance tables, it says distributer rpms in the rpm column and camshaft or distributer degrees in the degree column. Your numbers are correct.
Anyway, I really appreciate the offer! I have yet to dig into it and see what the bearings look like.
Barry
Old Feb 5, 2003 | 10:54 PM
Mike W's Avatar
Mike W
At my wits end!@!
I got to think about this some more except I'm too tired.
