But, is it worth the money? It's up to you. I know they are getting some really dollars out of some of these simple little devices.
I suggest finding a welder(or friend who welds) and making one. A couple elbows, a hack saw and Viola'...X-pipe. I'm sure the who you buy may look really special , but if you can cut straight, weld good, it will work just as good.
Will the Bassani X-Pipe for the lightning work for a 4.6L f150? I know that the Lightning has a 5.4L in it but I was just wondering if it was the same block used on both engines. I am specifically looking for a good highflow cat system.
It doesnt really matter what vehicle the x pipe was intended for as long as there is room for it and ifyou can weld your pipes to it. I just had and x pipe installed on a 95 3/4 ton 4x4 with 460 and love everything about it. It sounds really.....really......cool!
