injector cup sealant
Old Nov 13, 2013 | 05:11 PM
jgilrfr's Avatar
jgilrfr
what sealer should i use on an early 99 injector cups,and any ideas where to get it,thanks
Old Nov 13, 2013 | 05:19 PM
Bonanza35's Avatar
Bonanza35
What ever comes with the new cups. Riffraff sells the cups and sealant. I believe that is what people do to use ELC on the early 99. Its a Loctite just don't remember the number, I think its 620 but someone will chime in soon.
Old Nov 13, 2013 | 05:37 PM
Tugly's Avatar
Tugly
Loc-Tite 620
Old Nov 13, 2013 | 08:12 PM
whitetmw's Avatar
whitetmw
#620 let it sit for about 30 minutes if you start it without the valve covers on - Take time to clean the surface with some very fine sandpaper. A dremmel with a small wire wheel works great - you don't want to have to go back in..... trust me
Old Nov 14, 2013 | 04:43 AM
Tugly's Avatar
Tugly
I let mine cure overnight (heat lamp on it). After the 24-hour cure time, I shoot some silicone spray into the hole, wetting the edges of the cup. I puff the degas bottle up to 15 PSI and watch for bubbles from the cup.
The pressurized degas bottle is how I found which cup was bad the first time around.
Old Nov 14, 2013 | 06:56 AM
BWST's Avatar
BWST
Got Data?
Rich, how did you know silicone spray would bubble? That does not strike me as a fluid that would do that, but I like the idea instead of soapy water.
Old Nov 14, 2013 | 07:43 AM
Tugly's Avatar
Tugly
I wasn't looking for foamy-type bubbles, I was looking for tiny burps. Any fluid will supply this, so I went with something harmless. I don't like the idea of putting anything in the hole that I don't want to accidentally get into the fuel rail. Some clean diesel in a spray bottle would do the trick as well.
bcarless
Aug 6, 2015 07:25 AM
farmert
Oct 4, 2013 10:17 AM
bcaughhorn
Apr 21, 2012 08:20 PM
