power steering
Old May 27, 2010 | 11:52 AM
jmikeyj4's Avatar
jmikeyj4
power steering
so i have a slight crack in my power steering reservoir and i dont wanna a get a new one. is there anything i can use to patch it up so fluid doesnt drip out
Old May 27, 2010 | 05:40 PM
RangerHaywood's Avatar
RangerHaywood
take the resevoir out and completely clean it as much as possible, then just dab some plastic epoxy over the crack and let cure. Hope this helps!
Old May 28, 2010 | 08:52 AM
jmikeyj4's Avatar
jmikeyj4
it does thank you
Old May 28, 2010 | 10:31 AM
4x4 Bart's Avatar
4x4 Bart
Make sure you have all the oil off the surface. Use an epoxy that is "not clear", use the heavy gray kind, Jbweld is good, I like Devcon better. I slightly rough the surface with sandpaper to give grip. Give it plenty of time to cure before use. A nice thick coat is stronger than thin.
Old Jun 2, 2010 | 09:02 AM
jmikeyj4's Avatar
jmikeyj4
thats exactly what i did
