Sponsored by: Real Truck
4r100 probem
Old May 27, 2010 | 09:59 AM
smccatv's Avatar
smccatv
4r100 probem
I have no forward at all but reverse and park are fine..This is my income truck 00 F450..I was working late and put the truck in reverse to work on a power pole. I finished up and proceeded to leave and no forward 1,2,3. Reverse worked fine..Check cable and it was moving. Checked atf level ,fine. It did not have any slipping, vibrations before this. I drove truck in reverse to a safe location..Drained pan and removed pan and filter. No pieces in pan.Help
Old May 27, 2010 | 02:03 PM
mwsF250's Avatar
mwsF250
Is the O/D light on or flashing?
Old May 27, 2010 | 04:29 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Is there a way for you to pull the codes?
Old May 27, 2010 | 06:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Codes won't help. Something mechanical broke.
Old May 27, 2010 | 06:50 PM
smccatv's Avatar
smccatv
pulling tranny now, will update later on what was found. You don't need to jack up a f450 to pull tranny!
Old Jun 17, 2010 | 09:19 PM
smccatv's Avatar
smccatv
Transmission guy did not find anything broken after dismantling it. He hooked up air and found the center support engaging slower than it should be. Amazing that the foward was there one minute and gone the next..
