Turbo Backpressure
Old May 26, 2010 | 08:59 PM
Canadian_Cowboy's Avatar
Canadian_Cowboy
Turbo Backpressure
hey guys
so i browsed through a whole bunch of posts but couldnt really find a straight answer.
i want to know how much backpressure (if any) our turbos need to function "properly"
if i run a straight pipe will that be to much flow? should i go with cat only? or muffler only?
thanks guys!
Old May 26, 2010 | 09:02 PM
MacbooknMyTruck's Avatar
MacbooknMyTruck
It is only a myth, these diesels do not need any backpressure whatsoever! I am running a full 4" straight pipe and runs like a champ ... sounds great too
Old May 26, 2010 | 09:26 PM
cheezit's Avatar
cheezit
any more then 4" you start to lose the bottom end power and suffer from lag.
Old May 28, 2010 | 12:25 AM
Canadian_Cowboy
the reason i ask is because my best friend and i both have 07 6.0 but his is a four door whereas mine is an ext cab. we run the same programmer on the same settings and no mods expect i have a stock pipe straight pipe. where he has 4 inch with cat still in. when we go out he hauls a 4x4 quad in the box yet still goes about 250-350 kms more ona tank of diesel than i do. any thoughts?
Old May 28, 2010 | 12:36 AM
Mark _G's Avatar
Mark _G
Is his a long bed and yours a short bed? If so his tank is bigger. But since you said the same, probably not.
Maybe he drives smoother or doesn't accelerate as hard as you do? Does he do more highway driving than you do?
Mark
Old May 28, 2010 | 12:56 AM
Canadian_Cowboy
no we did a side by side test after a few times of him heckling me about my fuel economy. same 100 liters in the tank then a drive. and my shame
Old May 28, 2010 | 01:18 AM
Mark _G's Avatar
Mark _G
Strange.
Old May 28, 2010 | 06:55 AM
DSMMH's Avatar
DSMMH
First thing, a turbo needs "0" back pressure to operate. On the 6.0 any exhaust back pressure inhibits turbo performance. After I took the cat out and put the MBRP cat delete pipe in the remaining stock exhaust system, the first improvement I noticed was improved low end throttle response, i.e., reduced turbo lag. After I replaced the stock exhaust with a 4" MBRP exhaust, I eliminated all turbo lag.
With the straight pipe, your turbo is reacting quicker then your friends. Under the same load conditions, your initial RPM will be higher then your friends. Higher RPM = more fuel.
I would venture a guess that if you drove his truck, his throttle response would be less then yours.
DSMMH
Old May 28, 2010 | 08:50 AM
ehgeeray's Avatar
ehgeeray
How many km's to a tank does he get? How many km's to a tank do you get? He must be messing with you...
Old May 28, 2010 | 07:16 PM
Canadian_Cowboy
nah man hes not messing with me. ive see it in a side by side drive. i get about 650-750kms to a tank and he gets almost 900-1000
plgebbia
22
Sep 13, 2017 01:37 PM
Yacomash800
Oct 29, 2010 07:21 AM
CheaperJeeper
13
Aug 5, 2008 12:40 AM
1994diesel
24
Mar 14, 2008 11:14 AM
BrianA
Exhaust Systems
62
Dec 22, 2004 03:24 PM
