About to do oil change, think this is the right oil to be using?
on
Yep.. Run 5w40 year round.. Once the engine is warm the "40" number is the important number... the "5" is the viscosity when the oil is cold..
I suck my HPOP.. it only takes a few minutes.. I just don't like to leave that extra quart of dirty oil in the system.. My next project is figure out how to suck the oil cooler.. Do any of you guys out there do that ?
Looks like I won't worry about the HPOP. From reading some posts here, it seemed some were finding gunky oil in it even after an oil change and was thinking the circulation was low enough to warrant changing it out. Maybe not. Next oil change, I'll probably suck it out as part of the procedure. It'll take a long time for me to build mileage on it though.
Thanks.
Thanks.
Number 8 in this diagram.
The Delo oil you have pictures is being used by many on this forum in their 7.3s, the Wix filter is also being used by some as well-some report their engines like the Delo oil better than anything else-we all recomend staying AWAY from FRAM filters.
I personally run Shel Rotella 5w40 Synthetic with a Purolator "PURE ONE" filter.
First I have heard of this?
I run Rotella...
So, FRAM is 'junk'?
See:
Oil Filters Revealed - MiniMopar Resources
and
http://minimopar.knizefamily.net/oilfilters/fram1.txt
It's a lot of reading, but a lot of information, too.
Pop
and
Pop
#30
See:
and
Pop
and
Pop
