VHT flameproff on IC pipes
Old May 27, 2010 | 05:26 PM
60RatRod's Avatar
60RatRod
Originally Posted by mongo75
Easy way to cure VHT if used on a IC pipe- run a length of wire through it- uncoated wire- hang it up to soemthing, I hung mine off a screwdriver jammed in my garage door frame while it was open. Spray the IC tube, or whatever part you want, then after it's fairly dry, heat it from the inside with a propane (or mapp gas) torch. Not too much, just enough to get it pretty dan warm to the touch. That oughta get it set right.
Ditto
Old May 27, 2010 | 08:17 PM
rat49f6's Avatar
rat49f6
thats funny because we actually used a electric heat gun to cure petes some before we reinstalled it
no need now NEST has a oven and im going to get powder coating system on Sat
Old May 27, 2010 | 11:27 PM
60RatRod's Avatar
60RatRod
Let us know how that works out. I have an extra propane powered oven, standard size, and have been considering getting the harbor frieght PC system, only problem is I don't see larger parts like IC tubes fitting so Im still up in tha air, not to mention my garage is only 440 sq ft and is pretty damn full with tool boxes, work benches, compressors, etc.
Old May 28, 2010 | 06:57 AM
rat49f6's Avatar
rat49f6
electric house oven off craigslist - $20
Oven cord - $25
Harbor freight powdercoat kit - $70
Figure its worth a shot
Old May 28, 2010 | 10:58 AM
60RatRod's Avatar
60RatRod
Oven cord - $25
When you put it like that, less than a $100 bucks to get started, I looked into the kit a little closer, and HF does'nt sell "blue" now Im blue
Old May 28, 2010 | 11:40 AM
rat49f6's Avatar
rat49f6
I'm looking at getting a few colors to test with then illl probably start using Eastwoods products
Old Jun 18, 2012 | 09:47 PM
spastik monkey's Avatar
spastik monkey
Ditto
Is that the VHT paint or powder coated? It looks great
Ford_Fan1
Ford Truck Parts for Sale
May 16, 2015 07:01 PM
jgavac
Exhaust Systems
May 14, 2012 05:57 PM
snakedoc
19
Jan 26, 2012 02:02 PM
ScaldedDog
Mar 11, 2011 10:25 AM
viking89
28
Jun 23, 2010 04:50 PM
