Belt jumping off
Old May 25, 2010 | 10:27 PM
Chad102's Avatar
Chad102
Belt jumping off
I recently changed out my ac compressor, and since then my belt has jumped off the pulleys twice. I had a shop look at the pulleys to make sure they were aligned properly, and they said everything looks fine. The shop told me that the lid on my powering steering pump was loose, and that the fluid was gettng on the belt and causing it to jump off track. Does this sound right to anyone? I feel like I am still waiting for the belt to jump off again.
Old May 25, 2010 | 10:50 PM
littlehusky's Avatar
littlehusky
i would look at the tensioner.
bearing siezed or its loose........
Old May 25, 2010 | 10:56 PM
Chad102's Avatar
Chad102
Thanks, I replaced the tensioner about 6 months ago. Can ps fluid cause the belt to jump? I'm having a hard time buying it
Old May 26, 2010 | 09:57 AM
Ed Bamba's Avatar
Ed Bamba
If the belt didn't jump off before the compressor replacement, I would have to guess that the new compressor is not aligned to the rest of the pulleys. That's providing no other component was removed and replaced for the task. When I replaced my PS pump, the belt was riding up on the pulley. I had to press the pulley in a smidgen, which cured the problem.
Old May 26, 2010 | 10:15 AM
quicklook2's Avatar
quicklook2
check water pump bearing.
thejermsr
105
Oct 8, 2025 09:24 AM
CoreLokt
Mar 14, 2016 06:13 PM
fuelhog450
Apr 13, 2013 02:58 PM
JAFO1
15
Dec 2, 2009 07:19 PM
Katt
Dec 25, 2000 05:14 PM
