Fuel Additives
Old May 25, 2010 | 09:09 PM
izzybird's Avatar
izzybird
Fuel Additives
I'd like to get some general thoughts on what additives, if any, y'all are using in your trucks. I've been making small batches of bio with very gently used oil, since they came out with the ultra low sulfer fuel, and using that as a lubrication additive. I just don't have time to mess with it anymore and am looking at having some bought stuff on hand when I run low on the bio.
Old May 25, 2010 | 09:40 PM
clintbonnie's Avatar
clintbonnie
Biodiesel is good.... Try some Stanadyne every every 3rd tank full or so...
Old May 26, 2010 | 12:06 PM
aklim's Avatar
aklim
I haven't found any additive that proves it will do something other than change the combustion noise. I extrapolated from an article written by Bosch that shows a maybe 10% life loss http://www.arb.ca.gov/fuels/gasoline...22003bosch.pdf between what they want and what is available. Is it worth the money and time and hassle? I think not. If the rebuild cost on injectors is say $2000, 10% of that is $200. That means it costs you $200 more to run regular diesel. Alternatively, ASSUMING that their stuff works as said, you save $200. However, you probably will spend more than $200 over the time the injectors wear out. IOW, to save $200, you spend more than $200. Is it worth it? I think not unless you want to go for the mileage record.
Edit: I have yet to find any additive that proves it will do something COST EFFECTIVE.
Old May 26, 2010 | 06:34 PM
Supercab's Avatar
Supercab
I use Power service Diesel Kleen from WalMart-not the best stuff out there by any means but its readily available.
Old May 26, 2010 | 07:15 PM
F350-6's Avatar
F350-6
I like additives if I'm not running some Bio. I usually use Stanadyne, but have used Power Service Diesel Kleen and some Howes before.
What's the record? I'm game. Close to 330,000 miles on my injectors now.
Old May 26, 2010 | 07:21 PM
aklim's Avatar
aklim
I'm not sure. Might be in the same category as HP/cc.
jayro88
Mar 18, 2014 10:57 PM
jaeh1
Feb 27, 2011 08:43 PM
F350long
15
Jun 15, 2007 10:45 PM
bio-d
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 9, 2007 01:16 AM
johnny8
19
Jun 16, 2005 08:56 AM
