Neverending problems F350
Old Feb 3, 2003 | 12:59 PM
Kgaidos's Avatar
Kgaidos
We have been having neverending problems with our F350 7.3. The right bank consistently fails when we are driving. We have taken the truck to the dealership twice and spent over $3000. So far we have replaced the cam sensor, water pump, computer, o-rings, vacuum pump, and some others that I can't remember right now. We took it to the shop the other day and it kicked out the right bank codes again. We are thinking that it may be electrical. Anyone have any ideas?
Old Feb 3, 2003 | 08:29 PM
HTRDDSL's Avatar
HTRDDSL
could explain what you mean when you said the right bank consistently fails while driving
and if at all possible can you tell me what codes the NGS was spitting out on your truck
There could be serveral things or just a couple of things that might be wrong, you were saying that the replaced your O-rings at on time, did they pull the wiring harrness back in correctly on that side of the motor, 2 Cam sensor, last time I check they had 9 udates on the cam sensor alone,
Did they replace the MAP sensor too? or the ICP sensor and the wiring, sometimes when the ICP goes bad it will short out the wiring and I have seen this many times, Have they done an voltage, and Ohms test on the IDM yet??
Sorry about this but I really would like to know what you meant when you said the right bank fails??
Old Feb 4, 2003 | 11:22 AM
Kgaidos's Avatar
Kgaidos
Right Bank Failing all the time: every couple days the right bank of cylinders stops firing all together. It is as if something is causing the injectors not respond at all.
The injector O-rings were replaced, the Injection Control Module was replaced, the valve cover wiring harness was replaced.
C
Old Apr 27, 2004 | 07:47 PM
ugly02f350's Avatar
ugly02f350
Same problem, did you get
Hi,
I am currently having the same problem. I have replaced the uvc and the IDM. I had the 10k mod done, and I think it caused the problem.. I had the truck for 4 months, 1 week after 10k mod this happened.
Cant figure it out, code 1316 IDM codes stored is what the computer says, I still need to to the koeo test to get the idm codes out.
Map sensor failure or ICP could cause this? Does is actually cause a short (burn) the wiring harness somewhere? or does it fix itself when you get rid of the bad map sensor or bad ICP.
Please help, I need my truck running, Ford dealer is not an option...
Thanks,
Scott
Old Apr 27, 2004 | 11:12 PM
HTRDDSL's Avatar
HTRDDSL
Does the truck even run right now?
Old Apr 27, 2004 | 11:57 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
FJ: IDM Electronic Feedback (EF) FJ: Introduction
FJ1 DIAGNOSTIC TROUBLE CODE (DTC) P1670 and P1668
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
Open fuse
IDM relay
Open or shorted IDM enable circuit
Open/short in EF circuit
Open/short in FDCS circuit
IDM powering circuits
PCM
Check for other codes.
Key on, engine off.
Perform KOEO On-Demand Self Test and retrieve Continuous DTCs.
Was DTC P1668 present?
Yes- If DTC P1668 is present, GO to FJ2 . No- If DTCs P1667 and P1663 are set together with or without DTC P1668, GO to FJ6 .
If DTC P1298 is also present, REPLACE the IDM.
If DTC P1667 is also present, GO to KA1 .
If DTC P1663 is also present, GO to KF1 .
If DTC P1662 is also present, GO to NC1 .
If P1670 was set without any other DTC, GO to FJ10 .
FJ2 CHECK CIRCUIT 818 (GY/W) FOR OPEN
Install breakout box; leave PCM disconnected.
Disconnect the IDM harness connector.
Measure resistance on Circuit 818 (GY/W) between PCM Test Pin 48 and IDM harness connector Pin 4.
Is resistance less than 5 ohms?
Yes-GO to FJ3 . No- REPAIR open in Circuit 818 (GY/W). RESTORE system. CLEAR DTCs and RETEST.
FJ3 CHECK CIRCUIT 818 (GY/W) FOR SHORT TO GROUND
Measure resistance between IDM relay Circuit 818 (GY/W) and battery ground.
Is resistance greater than 10,000 ohms?
Yes-GO to FJ4 . No- REPAIR ground short in Circuit 818 (GY/W). RESTORE system. CLEAR DTCs and RETEST.
FJ4 CHECK CIRCUIT 818 (GY/W) FOR SHORT TO POWER
Key on, engine off.
Measure for voltage on Circuit 818 (GY/W) between PCM Test Pin 48 and battery ground.
Is voltage present?
Yes-REPAIR short to power on Circuit 818 (GY/W). RESTORE system. CLEAR DTCs and RETEST. No- GO to FJ5 .
FJ5 CHECK SIGNAL RETURN CIRCUIT 359 (GY/R)
Measure resistance on Circuit 359 (GY/R) between PCM Test Pin 91 and IDM connector Pin 2.
Yes-GO to FJ6 . No- REPAIR open in signal return Circuit 359 (GY/R). RESTORE system. CLEAR DTCs and RETEST.
FJ6 CHECK IDM POWER
PCM connected, IDM disconnected.
Key on, engine off.
Measure voltage between IDM connector Pin 14 and battery ground.
Is B+ present?
Yes-GO to FJ7 . No- GO to NC6 .
FJ7 CHECK IDM GROUND
Key off.
Measure resistance between IDM connector Pin 26 and battery ground.
Yes-GO to FJ8 . No- REPAIR open in IDM ground Circuit 574 (BK/PK). RESTORE system. CLEAR DTCs and RETEST.
FJ8 MEASURE FREQUENCY ON THE EF LINE
Connect PCM to breakout box.
IDM connected to harness.
Set up scan tool as follows:
Connect scan tool to the DLC
Connect test probe between scan tool common and breakout box Pin 77 (ground).
Connect second test probe between scan tool signal and breakout box Pin 48 (EF line).
Select VEHICLE and ENGINE
Select DIGITAL MEASUREMENT SYSTEM
Change level to 4 VOLT DC
Press the link button to choose a PID
Select PID/DATA MONITOR
Select RPM PID
Press START
Key on, engine running.
Measure frequency at 3 different RPMs.
RPM Frequency (Hz)
1000 66
2000 133
3000 200
For each rpm value, does the corresponding frequency match closely to the table?
Yes-REPLACE PCM. RESTORE system. CLEAR DTCs and RETEST. No- REPLACE IDM. RESTORE system. CLEAR DTCs and RETEST.
FJ9 DIAGNOSTIC TROUBLE CODE (DTC) P1316 INDICATES THAT CODES ARE STORED IN THE IDM
Possible causes:
Injector(s) or circuit(s)
IDM relay
IDM
PCM
Key on, engine off.
Perform KOEO On-Demand Self Test.
Are IDM or any other codes stored?
Yes-GO to the appropriate pinpoint test. No- GO to FJ10 .
FJ10 DTC P1316 OR P1670, CHECK FOR AN INTERMITTENT OPEN CIRCUIT
Key off.
Install breakout box, leave PCM disconnected.
Disconnect IDM.
Check for intermittent open in the following circuits:
Measure resistance on (FDCS) Circuit 821 (BR/O) between IDM connector Pin 17 and PCM Test Pin 95.
Measure resistance on (EF) Circuit 818 (GY/W) between IDM connector Pin 4 and PCM Test Pin 48.
Grasp the harness close to the IDM connector. Wiggle, shake the harness while working your way back to the PCM, while looking for a spike on the DVOM.
Do all readings remain below 5 ohms throughout procedure?
Yes-GO to FJ11 . No- REPAIR open in the suspect circuit. RESTORE vehicle. CLEAR DTCs and RETEST.
FJ11 CHECK FOR AN INTERMITTENT SHORT TO GROUND
Check for intermittent short to ground on the following circuits:
Measure resistance on (FDCS) Circuit 821 (BR/O) between battery ground and PCM Test Pin 95.
Measure resistance on (EF) Circuit 818 (GY/W) between battery ground and PCM Test Pin 48.
Do all readings remain above 10,000 ohms throughout procedure?
Yes-GO to FJ12 . No- REPAIR short to ground on the suspect circuit. RESTORE vehicle. CLEAR DTCs and RETEST.
FJ12 CHECK FOR AN INTERMITTENT SHORT TO POWER
Key on, engine off.
Check for intermittent short to power on the following circuits:
measure voltage on (FDCS) Circuit 821 (BR/O) between battery ground and PCM Test Pin 95.
measure voltage on (EF) Circuit 818 (GY/W) between battery ground and PCM Test Pin 48.
Did voltage ever appear on any circuit throughout procedure?
Yes-REPAIR short to ground on the suspect circuit. RESTORE vehicle. CLEAR DTCs and RETEST. No-GO to FJ13 .
FJ13 VERIFY DTC P1316 AND/OR P1670
Restore vehicle.
Clear DTCs.
Cycle key off, than start engine.
Road test vehicle.
Was DTC P1316 and/or P1670 set in Continuous without any codes in KOEO On-Demand?
Yes-GO to FJ14 . No- REPAIR KOEO On-Demand DTCs. RESTORE vehicle. CLEAR DTCs and RETEST.
FJ14 ATTEMPT TO GENERATE IDM DTCS
Key off.
Disconnect one valve cover connector.
Start engine to generate IDM codes.
Perform KOEO Injector Electrical Self Test and KOEO On-Demand Self Test.
Are IDM codes retrieved?
Yes-REPLACE PCM, RESTORE vehicle. CLEAR DTCs and RETEST. No- REPLACE IDM. RESTORE vehicle. CLEAR DTCs and RETEST.
I've never had to deal with IDM problems. That is copy/pasted straight off the service DVD.
Old Apr 28, 2004 | 06:52 AM
GlennJenne's Avatar
GlennJenne
Boy Cookie, when you reply......you really reply! Great info for all of us, need to get that CD.
Glenn
Old Jul 24, 2006 | 08:57 AM
MarineDiesel's Avatar
MarineDiesel
Old Problem, New Problem
Hello all, not sure if anyone will recieve this post, since this is from 3 yrs ago, however I was curious if any one had any information on how Kgaidos solved his right bank failure issues. Plz resond asap!
Seth
Old Jul 24, 2006 | 09:08 AM
vettdvr's Avatar
vettdvr
CD what CD.. Is there something out there to read the codes and provide this info that doesn't cost the first born?
Old Jul 25, 2006 | 06:16 AM
IB Tim's Avatar
IB Tim
...Welcome Seth, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 26, 2007 | 09:24 AM
dhay69must's Avatar
dhay69must
for what it is worth. check the wiring harness that goes to the injectors. it goes thru the valvecover. it is prone to faliure and will cause and inter. short in the system which could cause your problem
jackstraw
Jul 4, 2017 08:14 AM
Neverending2014
Mar 30, 2016 05:26 PM
Neverending2014
Nov 9, 2015 06:58 PM
Tim Hodgson
65
Nov 30, 2012 01:22 PM
timbersteel
13
Nov 2, 2010 09:04 PM
