ideling problem while in gear
Old May 25, 2010 | 03:10 PM
fordman107's Avatar
fordman107
okay i have a 302 bored .30 over 280duration 512lift comp cam,edelbrock rpm performer intake, holly 650cfm carb, and headers and the transmission is a 3sp c6 automatic and when you put it in gear it will idle down and die its idling at about 1800-2000 maybe i need to get a stall converter for my tranny? thanks for answers
Old May 25, 2010 | 06:38 PM
frankensteined_67's Avatar
frankensteined_67
check all your vac. lines and your pvc valve also the vac valve on the distributor (sorry cant think of the name). that's where i would start. check all your lines and check the psi on your lines too. vac leaks can do exactly what you are describing
mustangnewby
Aug 19, 2014 02:01 PM
janvan.1
2004 - 2008 F150
Apr 25, 2010 05:32 PM
aleh61
Aerostar
Apr 8, 2009 04:26 PM
smokey6309028
Apr 4, 2008 09:49 AM
ottman
Aug 8, 2000 07:50 PM
