Computer chip tunning BS??
Old May 25, 2010 | 12:03 PM
KATAI's Avatar
KATAI
Has anyone used any of these computer chip tune up thingies? (<-- technical term)
If so did you notice anything, worth it? BS??
If you were happy with it which one did you buy?
Old May 25, 2010 | 12:17 PM
drunkensailor's Avatar
drunkensailor
Yes, many have used them. Some are BS, some are relatively useful, and the best option is going to be the one for your specific application. Having said that, if you got a V10, hit up the V10 forum in the performance section, look at anything mentioning 5startuning, he will get you a tuner program specific for your application with all mods, right on down to the throttle body spacer(.) If you have a Diesel look in the diesel section and they will point you the right way(I believe they still have a couple good sources for tuning). Let us know how it goes.
Welcome.
Old May 25, 2010 | 12:18 PM
fordboy67's Avatar
fordboy67
X2 on 5Star tuning. Highly recommended!
Old May 25, 2010 | 03:25 PM
EXv10's Avatar
EXv10
There are probably a few that help somewhat after you wade through all the hype.
Old May 25, 2010 | 04:46 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
my sct tuner from 5 star tuning made a huge, instant differance. well worth the money. the trans shifts where i want it to now, has tons of power puts a grin on my face every day .
Old May 25, 2010 | 07:00 PM
EXv10's Avatar
EXv10
That's great AK, I am just going by general experience with gadgets in the past. I actually almost bought one but had to remind myself those days are over. I did read a lot of hype when I looked into it. That's what is good about FTE, you can get real testimonials.
Old May 25, 2010 | 07:30 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
the extra power is great but having the tranny shift how i want is what really did it for me..made driveablity for me so much better! theres hype for a reason lol i allways questioned them before..but now i know.
only problem is i want a tuner for some of my other trucks now...that could get expensive!
Old May 25, 2010 | 08:54 PM
ocrush's Avatar
ocrush
I have a DP F-5 chip in my 2000 7.3 Diesel VERY happy with it.
Old May 26, 2010 | 12:32 AM
wallz's Avatar
wallz
Can't you just get a tune writen for the other fords you have and run them in. Maybe I just don't understand them, cuz I am just starting the process, but I thought you flash the PCM and then unplug? I just don't know if I should wait to get mine before or after the planned y pipe and headers.
Old May 26, 2010 | 03:07 AM
Stewart_H's Avatar
Stewart_H
A chip (hardware) is installed on the PCM and has a tune (software) written for that specific vehicle, taking into account whatever the specific mods it has, if any.
A flash tuner plugs into the OBD 2 port, copies the original factory tune, then uploads the custom tune to the PCM. Once done, the flash tuner (Predator, SCT, Superchips, etc) is VIN locked to that vehicle.
So you see, whether you choose a chip or a flash tuner, you need one for each vehicle, and the appropriate tune for each vehicle. That gets pricey.
To the OP, depending on what engine you have, a custom tune will help you a little, or it will help you a lot.
If you have a gasser, it will help a bit, but not nearly as much as a custom tune does for a diesel, because the factory tune on diesel rigs leave a lot of power and performance on the table, untapped.
Stewart
Old May 26, 2010 | 12:29 PM
jdadamsjr's Avatar
jdadamsjr
As stewart stated -one tuner to one vehicle at a time .
meaning when you install a tune on a vehicle, it is married to that vehicle, and can't be installed on another similar vehicle until it is uninstalled on the first...
to the op, give us some info on your engine, etc.. and we can be more specific....
Old May 26, 2010 | 10:47 PM
EXv10's Avatar
EXv10
I kind of figured a diesel would benefit more than a gasser and that is probably why I never got one. I guess the diesel puts out more smoke when it puts out more power and that is why a lot of power is "left on the table".
Old May 27, 2010 | 09:28 AM
jdadamsjr's Avatar
jdadamsjr
Not necessarily
the bean counters detuned them for fewer warranty claims...
If tuned properly for the amount of air injected, no or minimal smoke....
smoke = wasted fuel.... burning all the fuel makes it more efficient and faster !
many dump more fuel so that's not the limiting factor
Old May 27, 2010 | 10:03 AM
howler4x4's Avatar
howler4x4
Nice explanation! Since this has become a general purpose tuner thread...
Once the tune is installed, can the tuner be removed? I'd like to keep my Scan Gauge II plugged in day-to-day.
Once I find a tune I like, it's not a requirement for me to be able to switch tunes easily.
Tks
Old May 27, 2010 | 10:11 AM
jdadamsjr's Avatar
jdadamsjr
Yes, my tuner stays in my center console.... 99.9% of the time
don't think I've changed my tune more than twice since inception
and that was to detune it for work... which SUCKS once you are used to the power
