Front Spring Part # -- 2C3Z-5310-WA (Z Code)
Rear Spring Part # -- 3C3Z-5560-CA (B Code)
Bilstein or Rancho 900xl's Front & rear Shocks
Hellwig Rear Anti-Sway Bar -- Hellwig # HW7643
RAODMASTER ACTIVE SUSPENSION (Ras)
caster/camber alignment bushings
questions are:
1- while i'm going to put shocks, rear springs, new rotors/pads on, should i just switch out my front springs for the extra $150 cost for the two springs since i have 125k on them?
RAS AND the F350 springs seems like overkill to me and might be pretty harsh. IMO I would do one or the other first, assess the situation for a little while, and then decide on the other. The RAS is probably the easier install, most of us seem to get about 1"-2" out of it. I would guess that you would be about level with the front spacer and the RAS. Personally I'd like to try Toreador's lift kit, but ...
As far as front springs go, I'm getting more to the "don't fix it if it ain't broke" age. The front coils are real easy change, if you change your mind later.
