Riffraff Plenum inserts FTW!!!
Old May 25, 2010 | 06:45 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I don't "beat on" or race my truck, but I do like to tinker, and after taking my intake spider off and on a few times, I was concerned about over-tightening the plenum clamps. Then I found out about the Plenum Inserts from Riffraff. Simple, solid engineering for a problem. I ordered them last Christmas but due to weather, moving, and then not being able to find them, I just put them in last Saturday.
You're not going to get a change like you will with good tunes, but it's nice to not have to worry about going too tight in such an inconvenient spot. Bonus is that I might have had a very slight boost leak there, but with getting everything cleaned up, re-aligned, and put back together tight, I've been getting on her a bit and my mileage has gone up just a hair. I know the lie-o-meter is just that, but the relative changes have proven quite accurate for me.
If you're going to be swapping turbos, up-pipes, or just have 2 hours and less than $100 to spare, you can't go wrong with these inserts. You'll never wonder if you can go just a bit tighter to avoid a leak, and to me, that's money well spent.
Thanks Clay!!
Old May 25, 2010 | 07:10 AM
jkidd_39's Avatar
jkidd_39
I 2nd this! I have them on 2 of my trucks now. They are a great cost effective product!
Old May 25, 2010 | 07:12 AM
riverrat41's Avatar
riverrat41
I have seen those and they really look rigid.He came out with them right after Chris(F350-6) and I installed the b-uppipes on my truck or I would had a set.Maybe next time.
Old May 25, 2010 | 07:13 AM
HD Rider's Avatar
HD Rider
Mine are still in the box waiting for me to make time to install them. They are almost too pretty to hide in the intake.
Old May 25, 2010 | 08:00 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Good deal Brendan. I think I will get me a set for the next time I take my spider off.
Old May 25, 2010 | 08:23 AM
PaysonPSD's Avatar
PaysonPSD
I also just installed mine, yesterday as a matter of fact while doing an HPOP R&R. I re-installed with t-bolt clamps. I agree, these inserts hold up to a good tightening. I did find that the stock plenums were a bit deformed and had to work on them a little to get them back to being round enough to get the inserts installed. I'm sure glad Roland (Mueckster) posted a tip about using a cotter pin puller as an aid to getting the spider back in the boots. It certainly made the job easier.
Old May 25, 2010 | 08:55 AM
mueckster's Avatar
mueckster
I purchased a set of the plenum inserts, as well. I talked with Clay, recently, and will be getting the rest of his boots before installing them and my RR. I already had the IC boots for my 6.0 IC install. He is going to fix me up with the rest of them. Thanks Clay.
Robin, I'm glad something I said was useful to someone. lol I've been using a cotter pin puller for hose removal and installation for years. I've even used it to pull cotter pins a few times.
Old May 25, 2010 | 09:03 AM
miller_feed
I once changed a tire using that little tab used to open a Miller Lite 10oz can. That, or maybe I opened a few too many of those cans.
Old May 25, 2010 | 09:05 AM
mueckster's Avatar
mueckster
You never cease to amaze me, Rick.
Old May 25, 2010 | 09:22 AM
PaysonPSD's Avatar
PaysonPSD
That was a great tip Roland. I bought the cotter pin puller about five months ago when I got the inserts. Haven't used it on cotter pins yet. But have used it on hoses and boots.
Old May 25, 2010 | 09:25 AM
sideshow's Avatar
sideshow
Yeah, well I broke into my own truck one time using just a quarter Seriously. Some "thugs" broke into my S10 blazer at orientation to college, and used a scredriver to jimmy the lock cylinder. I was a cheap college student, and just put some JB weld around it. After all, there was nothing to steal now that they got my stereo. One night I had locked my keys inside, and wedged a quarter out of my pocket underneath the cylinder and leveraged it out. My buddy was dumbfounded. Only persont to ever break into a vehicle with a 25 cent piece I also broke into my old jeep cherokee one drunken night using a friends house key, but that's another story.
Old May 25, 2010 | 12:57 PM
guzzle92's Avatar
guzzle92
I had to get a set of the inserts as soon as I saw that Clay had them available. It immediately struck me as a GREAT idea knowing how thin and frigile the stock plenums are. That's why Ford has standard worm gear clamps there and not t-bolt. The set I installed went in like a greased pig (it took a little tapping with a soft headed hammer ) but the worm gear clamps never saw the truck again and now sports t-bolts on all the boots.
Old May 25, 2010 | 01:15 PM
wolfrace's Avatar
wolfrace
You like apples?
I am doing some upipes and turbo work, I will putting them in, glad to hear you like em Brendan
Old May 25, 2010 | 05:41 PM
zx250's Avatar
zx250
Of the next Riffraff East
Old May 25, 2010 | 05:49 PM
Kwikkordead's Avatar
Kwikkordead
That's a great idea!
I have some of those clamps in the back, they are going on next time.
