Sponsored by: Real Truck
Starting issue
Old May 24, 2010 | 07:08 PM
01F250gold's Avatar
01F250gold
Starting issue
I have an 01 250SD with a 5.4 and when I start the truck early in the morning it wants to die unless you push the throttle to the floor and even sometimes when you push it to the floor it will still die after it runs for awhile and you tun the truck off it will start back up fine. Does anyone have any ideas for me?
Old May 24, 2010 | 09:29 PM
gearloose1's Avatar
gearloose1
Check for fuel starvation.
Usual cause, from weak pump, clogged filter, blockage, vacuum in line, etc. check with a pressure gauge and measure volume.
Then it is fuel injection system....
Old May 24, 2010 | 10:05 PM
01F250gold's Avatar
01F250gold
How do you change the fuel filter on these? Were can I get the special tool? I'm used to stangs were you just unscrew it. I believe this is most likely the issue since the plugs in the engine were so bad they looked like the original 01 plugs from 215k miles ago I doubt the filter has been changed since it was new.
