Noisy Fuel Pump
Old May 24, 2010 | 03:58 PM
uncwgrad1's Avatar
uncwgrad1
Noisy Fuel Pump
I just noticed today that my fuel pump is making am awful sound! Is this a sign that it is going to die? Can I just get a pump or do I have to rplace the entire HCFM?
2003 6.0 95,000 miles
Old May 24, 2010 | 04:09 PM
gearloose1's Avatar
gearloose1
Clean it first and see if that fixes it... new filters... test pressure...
If it still persists...
Old May 24, 2010 | 04:11 PM
uncwgrad1's Avatar
uncwgrad1
I just replaced filters ~1000 miles ago
Old May 24, 2010 | 04:20 PM
cartmanea's Avatar
cartmanea
Make sure you got the HFCM cap tight, could be sucking air.
Old May 24, 2010 | 04:24 PM
uncwgrad1's Avatar
uncwgrad1
Cap tight! Just checked
Old May 24, 2010 | 05:55 PM
toolman05kr's Avatar
toolman05kr
Replace the pump
Old May 24, 2010 | 06:30 PM
uncwgrad1's Avatar
uncwgrad1
Originally Posted by toolman05kr
Replace the pump
Pricey little sucker...isn't it!
Old May 24, 2010 | 06:53 PM
gearloose1's Avatar
gearloose1
I would test pressure, if it is good, then you got time --- and partsguyed does parts cheap and you can wait.
Old May 24, 2010 | 07:19 PM
Young Gun's Avatar
Young Gun
Are you planning on ever doing fuel system upgrades? If so you might as well upgrade the pump now so its done.
Old May 24, 2010 | 08:40 PM
gearloose1's Avatar
gearloose1
If you don't do off road, and don't need the ground clearance, the Horizontal Fuel Conditioning module,
Parker P3 --- or the larger ones --- is a far better unit.
Easier to change filters, easier to drain water, and just better.
Or just swap one off a E-350.. same idea.
Old Sep 26, 2010 | 11:31 PM
HeavyTow's Avatar
HeavyTow
Just bought a 2006 F-250 with the 6.0 and I'm hearing what sounds like a relay chattering under the hood when I turn the ignition to on. I can hear the fuel pump running, but the loudest noise is seems to be in the engine compartment. I've just changed all fuel filters with all Ford filters. Any idea if I'm on the right track & if so what it takes to fix it. The truck only has 21,000 miles on it.
Old Sep 27, 2010 | 12:06 AM
cartmanea's Avatar
cartmanea
Are you sure you aren't just hearing the injectors cycling? They buzz for 5-10 seconds when you first key on.
Old Sep 27, 2010 | 08:35 PM
HeavyTow's Avatar
HeavyTow
Yes, I am hearing the injectors cycling, but since I am new to the normal sounds of the 6.0 I didn't know that they did that. However, there are actually two other noises that occur during the key on period. The first is the fuel pump on the frame rail under the truck. It will continue to run for an additional 15 to 16 seconds after the injectors cycle if I don't crank the engine. The other noise comes from the small pump on the passenger side fender well that I think is possibly a vacuum pump. On an initial key on cycle it will run longer than the injector cycle, but not as long as the fuel pump. At other times it doesn't come on at all or only briefly. Does all of this sound normal?
Old Sep 27, 2010 | 08:43 PM
gearloose1's Avatar
gearloose1
Perfectly normal.
Old Sep 27, 2010 | 10:13 PM
HeavyTow's Avatar
HeavyTow
Thanks to the both of you for the reply about the noises.
HeavyTow
