replacing headlight switch
Old Feb 3, 2003 | 09:44 AM
EKG's Avatar
EKG
I need to replace the headlight switch on my 83 F150. What is the best way to get to it ? Pull the instrument pod or from underneath?EKG
Old Feb 3, 2003 | 12:03 PM
Jens's Avatar
Jens
Hi,
try this pic, maybe it helps.....
ftp://home-up.t-online.de/Auktion/Licht.jpg
Jens
Old Feb 3, 2003 | 04:26 PM
Franklin2's Avatar
Franklin2
Reach up in there by feel, and press the little secret button. I think the headlights have to be on (button has to be pulled out) for it to release so you might want to disconnect the battery. Once the ****/arm comes out, just take the nut off.
Old Feb 4, 2003 | 10:15 PM
steve83's Avatar
steve83
You have to pull the **** out to turn the headlights on, then push that button, then pull the ****'s shaft out of the dash. You can then release the button and lightly push the shaft back in to turn the lights off. If you push too hard, the shaft will lock back into the switch and you'll have to start over.
Old Feb 5, 2003 | 06:17 PM
EKG's Avatar
EKG
I know how to remove it the problem is getting to the damn thing. There is a steel plate under my dashboard that pretty much makes a simple job a horror show. I was hoping someone knows an easy way to get at the switch without spending hours taking th underside of the dash apart. I think part of the air conditioner is under that plate.
Old Feb 5, 2003 | 10:53 PM
steve83's Avatar
steve83
I've done it by pulling the instrument cluster, but there's no "easy" way.
...unless you're double jointed or have limber bones!-)
ekg_80
Mar 2, 2015 06:55 AM
ekg_80
1997 - 2003 F150
Dec 17, 2014 08:23 PM
ekg_80
1997 - 2003 F150
Dec 6, 2014 12:31 PM
The_X_Family
Jan 14, 2011 11:27 AM
