Is this normal?
Old Feb 5, 2003 | 08:05 PM
nzabka's Avatar
nzabka
Is this normal?
Got an 85 f150 w/351w in it. It's my first truck. The power steering pump has been leaking and whining quite a bit and even squeals when I get on the gas. I changed it out this past weekend, got the leaking stopped, but the thing still whines quite a bit. Just as loud as the bad one. Is this normal? It's really noticable inside the cab and annoys me. Am I too picky or is it supposed to whine? My uncle has an 82 with a 302 and I can't even hear pump whining when I drive it.
Old Feb 5, 2003 | 08:08 PM
Raptor01's Avatar
Raptor01
Is this normal?
How does the steering feel? Make sure that you have plenty of fluid in the pump. Also the line could be clogged
Old Feb 5, 2003 | 08:15 PM
nolanc2's Avatar
nolanc2
Is this normal?
That sounds like a loose or worn belt.
Old Feb 5, 2003 | 08:23 PM
nzabka's Avatar
nzabka
Is this normal?
No, no. The old PS pump squealed. The new one doesn't.
As for Raptor01's question, It feels fine. It's not plugged cause the fluid was definately flowing through the whole system when I bled the PS system.
It actual works fine, it just whines loudly. I got the new pump at O'reilly's. Was that my mistake?
Old Feb 5, 2003 | 10:32 PM
HotWhlz85's Avatar
HotWhlz85
Is this normal?
Most power steering pumps you buy are remans. There will usually be a disclaimer somewhere in the packaging stating that some noise is inevitible and normal. When I replaced mine on my 85 a month ago I had the same thing. What fixed it was replacing the fan belt and making sure it was tight. Quiet as can be now.
Old Feb 6, 2003 | 07:35 AM
nzabka's Avatar
nzabka
Is this normal?
Hmm. All the belts were brand new when I bought the truck last Oct., this I know cause I did it. So I guess I'll try to snug the belt up some more.
