coolant leak
Old Feb 3, 2003 | 08:03 AM
90RangerRandy's Avatar
90RangerRandy
coolant leak
I have a lot of coolant dripping off the front of the oil pan on my 90 Ranger 2.9L. I think its the waterpump but am not sure. Is there a way to check to know for sure? Thanks
Old Feb 3, 2003 | 09:18 AM
superrangerman2002's Avatar
superrangerman2002
coolant leak
you could pick up some leak detector at a local auto parts store, like Advance Auto or Napa.
Old Feb 3, 2003 | 10:25 AM
Bob Ayers's Avatar
Bob Ayers
coolant leak
Try pressurizing your cooling system, then you should be able to see it. The water pump has a weep hole in the bottom
of the shaft housing, this is where they normally leak...
Good luck!!!
Old Feb 3, 2003 | 01:52 PM
Mauser8mm's Avatar
Mauser8mm
coolant leak
Those 2.9's are knowen for there heads getting little cracks in them so check you oil for coolent hopfully its just a water pump gasket. Then do a pressure check also you can get this coolent die stuff that turns a differnt color so you can see where the coolent is coming out anyways good luck!
