Sponsored by: Real Truck
Modular V8 Expertise Needed
Old May 27, 2010 | 03:14 PM
5.4L to Freedom's Avatar
5.4L to Freedom
Originally Posted by TennesseeMustangPerf
Glad you got it fixed. Actually, I do use a little antisieze, but just a very slight dab. Lots of people overdo it thinking it is needed. Good job fixing it!
I didn't fix it, Delehanty Ford did... I woulda never figured that one out. Makes sense once it's explained to you tho
Old May 27, 2010 | 03:30 PM
mwsF250's Avatar
mwsF250
Glad to here she's better!
But I'm curious about the anti-sieze you used?
I have two kinds - one copper based and one nickel based. Both are highly conductive once the fastener is properly torqued.
Old May 27, 2010 | 03:47 PM
5.4L to Freedom
I used the autozone grey tube... I'm just repeating what I was told. When my rommate gets back I'm going to get his fluke to check the continuity of antiseize... his meter gives a continuity value.
Old May 27, 2010 | 04:04 PM
mwsF250's Avatar
mwsF250
Keep in mind that it will not be very conductive in the tube because all the metal particles are in a grease suspension. But once torqued, the grease is displaced and the particles are compressed tight against the threads.
So check continuity on tightened fasteners.
Old May 27, 2010 | 04:12 PM
SDTriton250's Avatar
SDTriton250
Good info for future reference... My previous truck, a 2500 Dodge with 5.7L Hemi, also used no anti-seize on the plugs. I don't recall about the COPs being a problem but proper torque of the plugs was the main concern. If Ford says no anti seize on the plugs, they will go in dry on my 5.4L as well...
Old May 27, 2010 | 11:30 PM
tawells01's Avatar
tawells01
This is from TSB 06-15-2. Admittedly it is for the 3V engine.
"...NEW PLUGS SHOULD BE INSTALLED USING A FILM COATING OF MOTORCRAFT HIGH TEMPERATURE NICKEL ANTI-SEIZE LUBRICANT (XL-2) ON THE GROUND ELECTRODE SHIELD OF THE NEW SPARK PLUG (FIGURE 7). DO NOT COAT THE ELECTRODE STRAP OR THE PLUG WILL MISFIRE. THE NEW PLUGS SHOULD BE INSTALLED WITH NO LUBRICANT ON THE THREADS AND TORQUED TO SPECIFICATION..."
Most plugs that do not have black metal should not require anti-seize especially those made of a nickel alloy. Additionally, the lubricant could allow you to over torque the plug. If you do use anti-seize lubricant on the threads, reduce the torque by about 30%.
Old May 27, 2010 | 11:35 PM
5.4L to Freedom
Tried to change my reps comment, did not know about the torque reduction! This is a potentially valuable piece of information! Thank you!
hofec1
2004 - 2008 F150
37
Nov 26, 2020 01:45 PM
fisher23112
Feb 1, 2015 02:22 PM
bleedin'blue
Dec 31, 2012 12:34 PM
Steveaustin
2004 - 2008 F150
May 24, 2009 10:07 AM
