Fuel problems
Old Jan 31, 2009 | 03:15 PM
Steveaustin's Avatar
Steveaustin
Fuel problems
I have a 2006 F150 5.4 and developed some codes the other morning.These codes read...p1075 bank 2 rich...p0300multiple misfire...p0307 cyl 7 misfire...p0316 misfire at startup first 1000 rev...p2072 throttle actuator control system ice blockage...and p2198 02 bank 2 sensor 1 stuck on rich.Running like crap and pouring fuel out of exhaust.I pulled the plugs and #7 cyl plug fouled bad.Other plugs were fine.I replaced all plugs,fuel filter,o2 sensor(bank 2 sensor one).It is still pouring fuel and code p2198 and p2196...bank 1 sensor 1 stuck on lean.
Can someone possibly make some sense of this mess and help me out?I am pretty sure that #7 injector is stuck open due to the fuel fouled plug but could that be causing all of my problems?
PLEASE HELP!!!!!!!!!
Old Jan 31, 2009 | 04:09 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Personally, I have no clue, but I guarantee you're scaring the hell out of everybody.
Old Jan 31, 2009 | 04:33 PM
Steveaustin
The problem started after a hard freeze one night last week there was a sheet of ice covering my truck.Is bank 1 sensor 1 showing stuck on lean to try and compensate for the over rich bank 2?I mean the fuel is literally running out of the exhaust!Sorry for the scare.....I am scared and stumped on this one!!!! And by the way I am not driving it this way for the fear of a possible bent rod or worse!!!!!!
Old Feb 1, 2009 | 10:52 AM
Steveaustin
So....I guess no one on here has ever had anything close to the problems I am having....possible stuck injectors....rich and lean 02 sensor codes...etc...etc?
Old Feb 1, 2009 | 01:47 PM
silver05fx4's Avatar
silver05fx4
first i would test the injector by remove the rail and set it up with a rag under it turn the hey to the on pos, then check the rail to see if the injector is leaking
what you saying sounds like a bad injector but its hard to tell injector are more of a 04 to 05 issue
or you could also switch a coil pack out with anotheir one to rule out them out
Old Feb 1, 2009 | 06:23 PM
Steveaustin
Thank you for the reply! In your opinion do you think that a stuck injector I would get a o2 sensor on that bank stuck on rich? I am also curious why now bank 1 o2 sensor is stuck on lean.What about the computer?I have an edge plugged in but it is just to moniter temps and nothing else.I have had 3 edge programmers in the past 3 years....sent them all back and got new ones due to problems that updates would not correct!!! I have also had my truck computer reflashed twice by the dealer....due to bad edge programmers!!!!
Old Feb 1, 2009 | 06:35 PM
silver05fx4
well i just think its some issue with your truck that can be easly fixed the edge just has a hapit of find them
Old Feb 2, 2009 | 07:20 PM
Steveaustin
Ok folks....here it is.
I just got my truck back from the dealer.Mutiple problems found.I got it all covered under recall....not sure how that happened but whos complaining!
p0307,p0308,p1116,p0442.They even changed my oil and filter due to fuel in the crank case.All of this done for a 100.00 deductible.
The beast rolls again!
Thanks to the (2) kind people that replied to my cries for help!
Old May 12, 2009 | 06:15 PM
tauthement's Avatar
tauthement
So, what did they find exactly? I am having similiar issues.
Old May 24, 2009 | 10:07 AM
74broncosport's Avatar
74broncosport
I am having similar problems too. I don't see any recalls for the '05 or '06 dealing with this issue. Anyone else have any ideas? I changed #1 and #2 plugs because thats what the Edge coded. Now all I have is P2196 O2 sensor signal biased/stuck rich/bank1 sensor1. I figured a plug problem caused the rich problem but it appears to be the other way around. I understand its not the O2 sensor and it may be the Air/Fuel mix sensor but where the heck is that and whats it voltage supposed to read?
zephyrprime
Jan 20, 2017 05:57 PM
zephyrprime
Modular V8 (4.6L, 5.4L)
Dec 21, 2016 11:20 AM
dockrocker
Feb 26, 2014 11:53 AM
Piratejonh
Oct 21, 2012 09:07 PM
dwhackney
Jan 14, 2011 07:02 PM
