Measurement Needed
Old May 23, 2010 | 07:09 PM
Wallywall's Avatar
Wallywall
Measurement Needed
I didn't think to measure the distance across the engine cross member before I cut it. It only moved a little when I cut through so it won't be a big deal if no one has it. Would any of you fine people happen to have that info?
Old May 23, 2010 | 07:14 PM
oldfordcoupe's Avatar
oldfordcoupe
i can ck tomorrow
Old May 23, 2010 | 08:21 PM
Bill W's Avatar
Bill W
What year truck? do you need inside frame edge to inside frame edge across where the crossmember goes?
Old May 24, 2010 | 07:29 PM
Wallywall's Avatar
Wallywall
Sorry about that, 1965. A year might help right! Yes Bill W, inside frame edge to inside frame edge. Thanks for the help!
Old May 24, 2010 | 08:12 PM
Bill W's Avatar
Bill W
Okay Wally, I get 29 inches at the backside of where the crossmember is (right before the steeringbox plate) and 29 inches in the middle.... in the front of where the crossmember begains the frame gets wider (about where the factory notches are for the crossmember section) it measures 29.25 inches
hope that helps you out. BTW, i measured my 65.
Old May 25, 2010 | 04:27 PM
Wallywall's Avatar
Wallywall
That's perfect Bill! Thanks!
