Edge Insight config
Old May 25, 2010 | 06:51 PM
hubler13f's Avatar
hubler13f
In which peramiter did you find the fuel economy selection. I just went through mine an was unable to find it. I just curious to see how accurate it is.
Old May 25, 2010 | 07:16 PM
rocky1074's Avatar
rocky1074
If you go into Choose Parameter click on the plus sign by fuel and fuel economy is the last one on the list
Old May 26, 2010 | 12:21 AM
flamebuster's Avatar
flamebuster
Bill; Yes the alarms will still activate even if you are on a different screen. It is a very neat feature. Your paramaters are a little higher than mine for the warning stages, but I got a feeling I will be changing mine when the ambient temps. warm up. I set mine like Tex 25025 but I kept. hitting the yellow warning on egt. and eot. so I set it up anouther 5 deg. I seem to run fairly steady at 831 egt's with no load and 950 on a short trip with the big 5er hooked on.
Rockyford 1075; I get voltage on my 2004. I believe it is on mod volt. I will check and post back..
Old May 26, 2010 | 12:29 AM
flamebuster
Rockyford 1075; You will probably have to use the computer selection. The sixth choice down is Sensors; double click on this and go down too the 32 cnd choice control module volts. click on this and it should give you system voltage.
Old May 26, 2010 | 09:30 AM
bpounds's Avatar
bpounds
Thanks, that's good to know. When I get a little more time I will purposely set something low so that I can see first hand how it alerts.
Old May 26, 2010 | 11:02 AM
rocky1074's Avatar
rocky1074
Thanks for the reply flamebuster, but is seems the 03 does not support volts. utjer & myself have 03's and both of us cannot show volts. I do have mine set in module volts like you said and is shows N/A. I will have to get a separate volt meter to monitor volts. Thanks anyway for for reply. Rocky
Old May 26, 2010 | 12:44 PM
flamebuster
Smile
When mine was alerting me because I had the egt. set low it turned the whole background color a dull yellowish green. I didn't realize it till I slowed for a turn and the screen returned to the bluish green color.I had the radio on so I don't know if it gave a tone. But now I know what to look for in color. Just in case it happens to you before you do your experiment....Doug.
Old May 28, 2010 | 12:24 PM
RigET's Avatar
RigET
That's exactly the kind of suggestion I was looking for. I don't know if those parameters are available, but I will check.
I have found Injector Pulse Width on my Edge, is that what you are looking for?
bpounds
Feb 20, 2021 05:19 PM
DIYMechanic
175
Jul 9, 2019 09:18 AM
bpounds
Mar 23, 2016 05:13 PM
bpounds
S. California Chapter
118
Aug 3, 2012 11:27 PM
bpounds
Sep 2, 2010 08:57 PM
