Question about full time 4 wheel drive
Old May 23, 2010 | 01:25 PM
wareaglehey's Avatar
wareaglehey
I have a 1978 Ford F150 with 351m and C6 transmission. I have full time 4 wheel drive. My "collar" that keeps my hub locked is badly worn on one side. It pops pretty badly when I shift in reverse and let off the gas. I am having trouble finding one of these collars or whatever the official name is. Would it hurt anything to put warns hubs in and just leave them locked in. I am eventually going to go to part time 4 wheel drive anyway.
TIA
Dan
Old May 23, 2010 | 01:56 PM
75F350's Avatar
75F350
Wont hurt anything at all.
If your local salvage yard does not have the drive slug assembly for your ford, you can consider looking at a chebby with a dana 44. The spline count is the same, and will fit your vehicle.
Old May 25, 2010 | 12:15 PM
bluesclu978's Avatar
bluesclu978
I have a 78 and 79 4x4 one is full time 4x4 and the other is manual locking hubs. Will I have to switch out the whole front axle to have part time 4x4 or just the hubs? New to this stuff so any help would be appreciated
Old May 25, 2010 | 02:02 PM
Fordworth's Avatar
Fordworth
As far as the front axle goes you only need to change the hubs, everything else is the same. The transfer case, however is the main part of the conversion. You can either install a part time conversion kit in the full time NP203 case or swap in a part time NP205. Swapping the entire case is a bigger project which requires driveshaft, shift linkage, and mounting modifications.
Old May 25, 2010 | 09:34 PM
phatjack81's Avatar
phatjack81
If the part time truck is just a parts truck and if the drive shafts are in good shape you could just swap'em to the full time as long as they are both 150's or 250's. Everything should be a easy bolt up. I could be wrong but I think if you take out the gear and spacer out of the full time hub and you should be able to swap in all the lock out parts to it.
Old May 26, 2010 | 08:15 AM
dynamic's Avatar
dynamic
Not sure if they make it any more, but my truck was the same configuration. PO installed a mile marker part time transfer case conversion kit, and installed locking hubs.
EDIT : MILE MARKER KIT Here is the link!
drewduncan15
19
Apr 10, 2019 08:37 PM
Uni Moe
21
Jun 30, 2017 11:04 AM
SchwartzStock
13
Oct 28, 2016 05:06 PM
Midnight Garage
Aug 9, 2016 04:59 PM
bowler300623
Jul 26, 2014 01:39 PM
