headlight switch please help
Old May 23, 2010 | 10:57 AM
powerstroker100's Avatar
powerstroker100
need to pull off that black panel to get to that nut thats on the switch but I don't know how to take off the panel can someone please help me, my switch is busted and I need to get it changed asap, also I hear about some pigtail that I should pull out and put a new pigtail on? please respond, thanks
Old May 23, 2010 | 11:10 AM
powerstroker100
Store Locator | NAPA Online
is this the type of switch I need to replace?
Old May 23, 2010 | 11:56 AM
White 97 xlt's Avatar
White 97 xlt
Does it look like this??
That is Echlin part number: HL 6663.
This is what I came up with for your 93 at NAPA..
Old May 23, 2010 | 12:35 PM
Volvo92906's Avatar
Volvo92906
What kinda dash do you have? If you have the one with the switched to the lower left of the steering wheel:
You have to remove the right side of the black panel which is held on with some clips you need to pull it off (dont break it). The other side has some torx screws holding it on and you need to remove those and pop the clips on it. Also, the wiper switch and headlight switch ***** are gonna be holding the panel on. The wiper one pops off but the headlight one you have to push a button on the actual switch which you probably need a long screwdriver to do. Youll know what im talking about when you see it.
Old May 23, 2010 | 01:11 PM
powerstroker100
thanks for help guys I got the dash off and pulled off the headlight switch, White97xlt that switch is the exact one I need its the same I pulled out, but here is my problem, the switch prongs looked fine but the pigtail was absolutely obliterated, it had been heated and was all warped and burnt looking, wires on the back of it were burned and chafed, I think I found the problem... But I'm in trouble now because I know nothing of wiring, do I order the new pigtail, cut the old one off, strip a little of the insulation off, twist the two wires together then solder and put shrink tube over it? do I need to do this for all 9 of the wires?
Old May 23, 2010 | 01:15 PM
Volvo92906's Avatar
Volvo92906
Thats probably the best way to do it. Not sure if they make a plug in harness to replace it.
Old May 23, 2010 | 04:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
.....put the shrink tubing on the wires before you twist and solder them together.
Volvo, There is a replacement pigtail. This problem is common.
Yep, that's the best way.
Old May 23, 2010 | 04:45 PM
Volvo92906's Avatar
Volvo92906
See, I knew someone would know! Haha. I havent had my truck for a while to look at it and I dont remember. Thanks!
Old May 23, 2010 | 04:55 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Most autoparts should have it.
Amazon.com: Pico 5311PT 1987-1993 Ford "F" Trucks Dash Headlight Switch Nine Lead Wiring Pigtail: Automotive
Old May 23, 2010 | 07:37 PM
powerstroker100
thanks guys, Update I have taken care of my headlight situation, kind of bummed out though because it took me all day between figuring out how to remove it, using epoxy on some broken plastic lol, and putting it all back together, todays plan was SUPPOSED to be brake fluid flush and, rear differential service but oh well, hopefully I can knock out the diff. service tomorrow after work
Old Oct 31, 2013 | 08:36 PM
infinite-foamies's Avatar
infinite-foamies
Does anyone have have a wiring diagram explaining what each wire does?
Old Oct 31, 2013 | 09:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Maybe this page helps?
Part 1 -How to Test the Ford Headlight Switch
Old Oct 31, 2013 | 09:31 PM
infinite-foamies
that did help! do you know what pins to jump for interior lights?
Old Oct 31, 2013 | 09:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Dome/courtesy lights or dash/instrument lights?
Old Oct 31, 2013 | 09:44 PM
infinite-foamies
both, replacing oem switch with some toggles
