87 f150 slow acceleration
Old May 22, 2010 | 10:44 PM
Meter maid Rita's Avatar
Meter maid Rita
Smile 87 f150 slow acceleration
87 ford f150 automatic 302 4wd
It Started with poor acceleration, so a tune up was done. Then it ran worse. Currently, truck cant accelerate fast enough to be on the road. Exaust manifold was checked -One was cracked and it was replaced, and the other was fine. Truck still cannot be driven. I have researched via the internet some of the problems that it might be, but I would like to know what everyone thinks. Any help would be great!
Thanks
-Rita
Old May 22, 2010 | 10:59 PM
Old93junk's Avatar
Old93junk
Plugged/collapsed catalytic converter, have the base timing checked also.
places to start.
Old May 23, 2010 | 05:38 AM
lew52's Avatar
lew52
Im with old junk , check the timing ,,,,Lew
Old May 23, 2010 | 11:27 AM
Volvo92906's Avatar
Volvo92906
Ah, so you figure it out! Sorry I took so long to reply to your message. Agreed on the others. A clogged Cat. Converter can cause that and timing being off can also. You put a bit more info in this thread than in the message which opened up more ideas.
Old May 29, 2010 | 11:35 AM
Meter maid Rita
Truck drives! - For now :)
Thanks for the tips. I replace the something that regulates the gas- a vaccum line plugs into it and it regulates the gas (not sure what it is called, but it costs $30). Drove the truck for 6 miles and it seems to get up to speed better then then before. The truck is now drivable.
Thank you,
Rita
Old May 29, 2010 | 01:28 PM
Volvo92906's Avatar
Volvo92906
Thank you,
Rita
Fuel pressure regulator.
Old May 29, 2010 | 03:36 PM
Meter maid Rita
Yes it was the fuel pressure regulator! I swear the guys at the parts store must think I am crazy. I go in there after compiling a list of the 'what it could be's' and they sell me the parts. I look on the internet at diagrams and how to guides of the way to replace it and give it a go.
The extent of my repairs are limited to - brakes, wheel bearing and the assembly set for winshield wipers(under the hood) on my pontiac, fuel pressure regulator, fuses, and so far thats it- But I guess learning starts somewhere. I appreciate everyones help and suggestions.
Thank You,
-Rita
78 & 87 Super Cab
Aug 25, 2016 09:34 AM
fordpower65
Mar 29, 2011 07:15 PM
Meter maid Rita
May 29, 2010 02:09 PM
packrat56
Mar 24, 2008 04:51 PM
mcsysho2
Garage & Workshop
Jun 26, 2006 09:51 AM
