volare steerig
Old May 22, 2010 | 11:06 AM
bbussman40's Avatar
bbussman40
volare steerig
Just went to alignment shop yesterday and was going to have my truck aligned again. They found that the alignment was great but they could hardly turn the front wheels back and forth. They thought I have a bad steering box. We took it for a road test and it will not recover from a turn, (letting go of the wheel) you have to recover from a turn by turning the steering wheel. Hope this makes sense.
Has anybody had this problem? There is almost 3 degrees caster so that can't be a problem.
Just a side note, I have an old dodge beater truck and jacked it up when I got home and I can turn the wheels left and right without any problem.
Old May 24, 2010 | 01:46 AM
Julies Cool F1's Avatar
Julies Cool F1
It sounds like the "toe" is set out not in if it has anything to do with alignment.
But I don't know on a Volare Front End.
But I'll bump this back up for another look for you!
Old May 24, 2010 | 06:43 AM
sdetweil's Avatar
sdetweil
I have a similar problem on my volare sourced truck.. I am running 5 degrees caster.. also took it to alignment on last Friday first time since I installed the camber shim plates.. the toe was off, and was corrected.. but still no change.
the alignment tech mentioned that he felt resistance when moving the wheels.. He thinks it might be a bound up ball joint.. and suggested unhooking the tie rods and turning the wheels to see if they move ok..
hope to do that this week.. everything is new on my front end.. so its either a bad ball joint, or a bad steering box..
Sam
Old May 24, 2010 | 08:32 AM
Okiedokie's Avatar
Okiedokie
Saw this somewhere and saved for future reference. Don't know if it applies, but I had never seen any info about this.
"Your control valve is out of adjustment. On top of the steering box where the 2 hoses go. Loosen the 2 bolts and center it. I watched my alignment guy do it while the motor was running. Slightly loosen them and tap it with a plastic mallet. He did it with the wheels off the ground until it no longer turned the tires. Blew me away. I was ready to buy a new steering gear. Ford pump on a Chrysler steering box, no problem (after the adjustment"
Old May 24, 2010 | 09:58 AM
bbussman40's Avatar
bbussman40
volare steering
I took the tie rods off yesterday and the wheels move back and forth real easy. The iddler arm was real tight so loosened that up and the tried to turn the pitman arm, applied 125 lbs. tourque and could not turn it.
That sounds like something to try before I have to replace the box. Did I mention that the truck steers with no effort at all.
I do have a ford pump, maybe the oressure is wrong?
To many questions.
Dennis
Old May 24, 2010 | 10:05 AM
bbussman40's Avatar
bbussman40
volare steering
What do you mean by wheels off the ground and and no longer turned the tires.
Old May 24, 2010 | 10:20 AM
sdetweil's Avatar
sdetweil
To many questions.
Dennis
yeh.. too many.. I am running a mercedes PS pump on mine.
I just have a lot of play and it doesn't center on its own like it should..
anyone know what the Chrysler PS pressure is supposed to be?
Sam
Old May 24, 2010 | 09:42 PM
raerjim's Avatar
raerjim
I too would like to know this.
Old May 25, 2010 | 08:08 AM
sdetweil's Avatar
sdetweil
I found that post on the HAMB on March of this year,
THE H.A.M.B. - View Single Post - Volare power steering in F100 ??
I have asked the poster if he could explain it more..
Sam
weyland426
Nov 21, 2013 09:44 AM
2000F250guy
Oct 18, 2011 11:42 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 9, 2010 07:14 PM
99F250Iowa
16
Sep 27, 2009 12:17 PM
oldsledder62
Bronco II
Apr 21, 2006 12:09 AM
