Festus,Thank you. I did find them on the web. What parts do I exactly need to add the tach to my truck and in your opinion would I just be better off to purchase the tach the runs off of the alternator which I have seen for around 90 bucks.
To add a stock tach you'll need to get the tach, the flexible circuit board from the back of the dash (it's different from the non tach board), and the sender from the engine. The wiring harness should already have the connectors needed to plug it all in. If not I can run through the simple wiring needed for it.
