Trans tepp guage
Old May 21, 2010 | 07:18 PM
Jim Hunt's Avatar
Jim Hunt
Trans tepp guage
Ok guys I did a search with no luck so I am asking here. Where do I hook the sensor up to for the tranny temp?
Thanks
Jim
Old May 21, 2010 | 07:58 PM
TexasDiesel97's Avatar
TexasDiesel97
on auto(e4od) there is a plug on the driver side of the transmission just about the pan. just above the second or third bolt of the pan.
Old May 21, 2010 | 08:24 PM
Jim Hunt's Avatar
Jim Hunt
I am assuming I pull the plug and put sensor in
Old May 21, 2010 | 08:54 PM
Brown Falcon's Avatar
Brown Falcon
Yes sir... pull that plug and put in the sensor. It'll give a good general temp reading. Not the hottest reading, but the average temp basically. If it gets over 200* start backing off a little. At about 225* things start to get bad inside the tranny.
Old May 21, 2010 | 10:02 PM
JamesHajek's Avatar
JamesHajek
3-Gauge Install Pictures
There is the spot for the sensor.
Old May 21, 2010 | 10:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nothing goes bad at 225°F inside the transmission.
Old May 22, 2010 | 08:27 PM
dshackle3's Avatar
dshackle3
Do you need a temp gauge on a stick shift with a chip?
Old May 22, 2010 | 10:11 PM
fordpride's Avatar
fordpride
No sir i'd say to overheat a hand shacker you would have to be trashing pretty hard
Old May 23, 2010 | 06:41 AM
dshackle3's Avatar
dshackle3
Thank you Fordpride
Old May 23, 2010 | 08:38 AM
etldak's Avatar
etldak
The ideal operating temperature for transmission fluid is between 175 and 225.Anything over that could boil the fluid.
Old May 23, 2010 | 07:45 PM
Mark Kovalsky
Transmission fluid doesn't boil until it is well over 400°F. Yes, I wrote four hundred degrees Fahrenheit.
