Engine question
Old May 21, 2010 | 07:01 PM
tardster's Avatar
tardster
Engine question
Hey guys n gals, I was wondering if I have to use a rear oil pump 289-302 to put in my truck. I went to go get one today and all the places I talked to said that the 289-302s from the late 60's were front oil pumps and so before I go spending the money I figured I would ask you guys to find out for sure first. I thought I had to have a rear oil pump. I still have the stock straight axle in the front. Thanks in advance...
Old May 21, 2010 | 07:57 PM
52 Merc's Avatar
52 Merc
Let's make sure we're all talking about the same thing. All small block Ford engines have only one oil pump, and it is located at the front of the block. There is no rear oil pump. That said, in certain applications, you may need to use a rear sump oil pan for clearance issues, especially if you're converting to an independant front suspension design. That will require a matchiing pickup tube to suck the oil from the rear sump to the front mounted oil pump. For your original straight axle, it will depend on how high or low you set the engine if you have a clearance issue, but you should be fine with the conventional, front sump pan setup.
Old May 21, 2010 | 08:03 PM
tardster's Avatar
tardster
Ok thats where I was getting confussed at was with the rear sump part of it. So I can take a 289 with the front oil pump and use it and if there are any clearance issues I can just get the rear sump pan and tube and then I will be ok right ( i hope I read that right)? Yes it has the stock front straight axle in it and as of right now I dont have any plans on changing that, I do know that there is probably about 3-4 inches of clearance between the oil pan and axle right now but its a inline 6 250.
Old May 21, 2010 | 08:13 PM
52 Merc's Avatar
52 Merc
You are correct. I installed a 289 and a C4 trans in a 1950 F-1 way back in 1977 and it fit with no problems at all with the conventional front sump pan. No firewall, frame, or crossmember hacking. I'm assuming nothing has changed with either parts over the last 30 years. ;-) It sat high enough over the axle I had no issues. You should be fine.
Old May 21, 2010 | 08:16 PM
tardster's Avatar
tardster
Awsome and thanks....
Old May 21, 2010 | 10:02 PM
tardster's Avatar
tardster
One more question, which or what motor mounts should I use with new motor?
Old May 21, 2010 | 10:09 PM
52 Merc's Avatar
52 Merc
You have several options, and a lot of the decision will be determined by your fabrication skill level. I like the idea of placing the engine in the truck where it fits best, looking at fan clearance, exhaust, angle, etc., and custom building mounts to have it sit there.
Old May 21, 2010 | 10:13 PM
tardster's Avatar
tardster
Ah I didnt know if I could just buy ones already made that would work on it, I thought I had seen some somewhere I just cant remember. I can weld or bolt them in if needed so thats not a problem. I'm not doing anything super fancy with her just want to drop in a 289 or 302.
Old May 21, 2010 | 10:24 PM
52 Merc's Avatar
52 Merc
Like I said, you have several options and many diferent pre-made mounts you can buy. The question will always be if the store bought mount will allow your engine to sit where you want it. That's why I always made my own to fit.
Old May 22, 2010 | 10:33 AM
Julies Cool F1's Avatar
Julies Cool F1
I had a 289 in my 55 and purchased a set of SBF Motor Mounts from JC Witney (this is 1985 and they were about all that was around) they worked fine.
Here's some typical ones:
Motor Mounts
LMC Truck Parts - Page 69
The ones I used were the same as in box #1 on the LMC page - worked great!
Old May 22, 2010 | 10:48 AM
lgwitt's Avatar
lgwitt
mounts
I was at a wrecking yard yesterday and saw mounts from 4 wheel drive pickups from the late 60 and early 70s that look like they would work with the frame rails boxed in the mounting area.
