steering colunm gone
Old Feb 2, 2003 | 10:07 PM
comertrucks's Avatar
comertrucks
I just bought another truck. It is a 68 (i think, no papers and vin # is for a motor home?) 1/2 ton short box 4x4 4spd. its a total basket case but has a cherry grille and a chrome rear bmper with the original brackets. But it has no steering colulnm. Does the column have to be for a 67-72 4x4 or has any one used other years or applications? I have two complete columns out of two wheel drive automatic trucks. Any info or ideas would be appreciated.
Old Feb 2, 2003 | 11:09 PM
zsir's Avatar
zsir
you can go up to 79....although you will have to work out the wiring for the turn signals.........4x4 or 4x2 the column is the same...the difference is the coupler that hooks to the bottom of the column...
Old Feb 3, 2003 | 06:00 AM
jowilker's Avatar
jowilker
comer, I don't think Ford built any motorhomes in 68, but I could be wrong.
Old Feb 3, 2003 | 11:07 AM
sparky's Avatar
sparky
Apparently they may have just built one
Old Feb 3, 2003 | 11:24 AM
460429_freak's Avatar
460429_freak
jowilker comer, I don't think Ford built any motorhomes in 68, but I could be wrong.
I have seen one, 1 ton 68 mint condition green in color will get pic one day
Old Feb 3, 2003 | 05:41 PM
jowilker's Avatar
jowilker
460, I thought I read that this one was a 1/2 ton 4X4 shortbed, motorhome.
and I did say that I could be wrong.
Old Feb 3, 2003 | 06:01 PM
1968F250LWB's Avatar
1968F250LWB
John,
I read that too at first but upon re-reading it I assumed he said what he had was a 1/2 ton 4X4 shortbed with a vin number (probably the one on the door) that said it was a motor home. A lot can change in 35 years including the doors! I know you guys say there is a vin on the frame somewhere but can't remember off hand exactly where.
Old Feb 3, 2003 | 10:07 PM
comertrucks
hey guys, guess I should have given a bit more info. Every body part is a dfferent color so I know they have been changed. The drivr side doorand fender are the same and the Vin # are on the door. When I took them to DMV (before buying the truck) they said it was a motorhome. But any way any suggestions on the missing steering column. My neighbor used to ave one of those motorhomes,they were built on the f-350 cab and chassis. Thanks for the help.
Old Feb 16, 2003 | 04:38 PM
B Wiltfong's Avatar
B Wiltfong
Yes, Ford indeed did build a motorhome in 1968, actually, they build the chassis, and somebody else put the camper part on, in mine, it happened to be Eldorado. It is on a 1968 F350, looks like a regular Ford pickup with a permanent camper on it!
Old Feb 24, 2003 | 10:42 AM
fast70's Avatar
fast70
check vin on passingers side under the hood on the chassi there you will find the vin number mite have to wire brush it give it a try good luck
Old Feb 24, 2003 | 02:48 PM
tw's Avatar
tw
The column is mostly the same from 67-79. It will fit fine, but the wiring changes after 72. The ones up until 77 will still look ok, 78-79 kinda look funny with the smaller wheel and larger hub.
Tony Warren
Nebraska
