Engine stand choices
Old May 21, 2010 | 03:25 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Hi all,
Ok, I need another engine stand, want lots of extra capacity mainly for stability, I'll be hanging my 6.9 on it.
What do you all think of these choices??
Harbor Freight - 2000 Lb. Foldable Engine Stand
JEGS #555-80042 2000 lbs. Engine Stand
The HF one folds up, I would think that would be shaky, it has the slotted head plate like I've always used, but it's HF ... some tubing bird crapped together barely covered with paint.
The Jegs one uses slotted brackets versus head plate, I've never used slotted brackets and think they might be a weak point, I also see it harder to make custom brackets, It's bolted together so it should be stable and it can be dissembled for storage, I suspect it's of better quality as well.
Thoughts, Opinions, Ideas, Recommendations??
Thanks
-Enjoy
fh : )_~
Old May 21, 2010 | 04:23 PM
bill11012's Avatar
bill11012
Modular motor junkie
I have the 1,000 one from HF.
It held my IDI but I could not turn it without taking some of the weight off with a hoist. The one from JEGs does not look much better than the nicer one from HF.
You should try to find a better one than thoes, but if your cheap like me than just get the HF 2,000 stand and call it good enough.
Old May 21, 2010 | 04:28 PM
oreocreaming's Avatar
oreocreaming
go for the jegs one. the extra set of wheels at the stress point make a nice difference. harbor freight ones tend to sag on the steel and stretch where the pins go though. ive got their engine stand, had to bend it back a few times and still leans.
Old May 21, 2010 | 05:21 PM
peruses's Avatar
peruses
I'd get the HF one with the replacement guarantee and take it back after I bent it up.
Old May 21, 2010 | 05:27 PM
oreocreaming
why take it back when you bend it up when you can just get one that wont bend to being with? and you dont think $30 extra is worth the time and effort to keep returning a product to the store, putting it together agian ect.
Old May 21, 2010 | 05:30 PM
peruses's Avatar
peruses
cause I wouldn't trust the jegs one not to bend either
and I only need an engine stand once every couple years
Old May 21, 2010 | 05:35 PM
oreocreaming
but your not festus. he may use it every day. and the jegs one isnt gonna bend from the idi.
Old May 21, 2010 | 05:36 PM
bill11012's Avatar
bill11012
It does not look any better than the HF stand...
Old May 21, 2010 | 06:19 PM
oreocreaming
front casters don't turn on hf stand. Rear steer only. Their wheels are cheaper and MUCH harder to roll, the jeggs one has 2 load bearing center casters for more wright distribution and easier to move.
Old May 21, 2010 | 11:36 PM
mechelement's Avatar
mechelement
Just at a glance, the JEGS looks superior to the HF engine stand. HF is typically junk. I've been looking at engine stands on craigslist and found some serious ones for ~$100-150.
Old May 21, 2010 | 11:59 PM
Festus Hagen
Methanoholic
Darn, I didn't mean to start a war...
Yup, It would be used frequently, In fact it'll likely have a motor of some sorts on it the rest of my life, the others I have are twinkies and would crumble under the IDI. I think they are 750 pounders.
I as well believe the Jegs unit will be of better quality. I suspect it'll be the one, never know with me until it's ordered...
A draw back on the Jegs unit, I've always found it easier to steer items like this that have fixed casters on one end, steering a heavy motor with all swivel casters is difficult.
-Enjoy
fh : )_~
Old May 22, 2010 | 12:09 AM
87crewdually's Avatar
87crewdually
Jegs got my vote. The HF one wouldn't surprise me if the head plate bent at the slots from all the IDI weight.
Old May 22, 2010 | 12:29 AM
bill11012's Avatar
bill11012
I think thats the way to go for something that will see lots of use.
Old May 22, 2010 | 01:28 AM
Festus Hagen
Methanoholic
I've been long distance ripped to many times on craigsripofflist ... If I can't find it where I can go physically I don't buy anything off craigsripofflist.
Though I must admit, I have had some excellent experiences as well and met some fine folks.
The last one was painful and I'll not go through that again.
-Enjoy
fh : )_~
Old May 22, 2010 | 02:25 AM
Festus Hagen
Methanoholic
Just laid out in bed, relaxed and it hit me ... The HF has no wheel bearings, the Jegs has ball bearings. DUH!
Thanks for the bat upside the head Oreo! I missed that one.
Pretty much seals the deal.
-Enjoy
fh : )_~
