Interesting Brake Issue
Old May 21, 2010 | 01:29 PM
BSCowboy's Avatar
BSCowboy
I've got a 1975 F-150, 2-WD LWB with Power Brakes. I replaced everything having to do with the brakes except the powerbooster. I noticed that my brakes have gotten a bit soft as of late. I checked out the master cylinder and the front reservoir was pretty low. I refilled it and remarkably the brakes work better now! So, problem solved right?
Well, if my brakes aren't leaking anywhere, where did all the fluid go? Do I have a problem I need to fix? Although the procrastinator in me says to let it go since they are working, i'm worried because they are, afterall, my brakes.
Old May 21, 2010 | 02:23 PM
4x4 Bart's Avatar
4x4 Bart
Low level in reservoir is an indicator of two possibilities.
A leak in the system, look for wet areas on brakes or tires, trace each line and look for signs of leaks.
Normal wear of the pads will slowly lower the fluid level.
Old May 21, 2010 | 05:03 PM
dogmantra's Avatar
dogmantra
OOps...
Originally Posted by BSCowboy
...Well, if my brakes aren't leaking anywhere, where did all the fluid go? ...
Sorry. I was running low and was in a pinch so I borrowed a small amount of fluid from your front reservoir. Forgot to tell you. My bad.
Old May 21, 2010 | 06:16 PM
wdfp's Avatar
wdfp
Your rear drums shoes and such can absorb a lot of fluid before they will start leaking outside onto the tires, so keep a close watch back there, it will show as lines on the tires sometimes all the way around from dripping onto it them being flung off as the tires goes round..
Old May 21, 2010 | 08:28 PM
Atwiss's Avatar
Atwiss
or when you put all the new breaks in it might of just had to fill the lines alittle just a small idea
Old May 21, 2010 | 09:42 PM
BSCowboy's Avatar
BSCowboy
Thanks so far, but y'all are missing the point.
First, the amount I replaced was definitely greater than the average amount one replaces due to disc wear, which I have never had to do on any vehicle I have owned. I'm not saying it doesn't happen, I'm just saying I put more than half a regular sized bottle in the front part of the master cylinder.
Like I said, assuming there is no leak in the system. Also, I didn't tell you this, but I have been driving the truck daily for over a year since I replaced all of the brake componentry. I don't know where the freaking fluid went!
Old May 21, 2010 | 09:51 PM
BSCowboy's Avatar
BSCowboy
I'm not saying this isn't the case, as you described it, but doesn't the brake system have a "component" that keeps the front and the rear part of the brake system separate?
Old May 21, 2010 | 09:52 PM
BSCowboy's Avatar
BSCowboy
Give it back!!!
Old May 22, 2010 | 02:02 AM
Dirt racer's Avatar
Dirt racer
I have seen the fluid leak into the booster and even get burned up in the engine vacuum system. Usually the booster doesn't last long when this happens. The diaphragm gets fluid on it and gets really big and doesn't work correctly anymore. If you booster is still working fine and there are no leaks, I would guess one or more of the rear cylinders are leaking some like wdfp said.
Old May 22, 2010 | 06:49 AM
BSCowboy's Avatar
BSCowboy
I had no idea that the fluid could leak into booster. If this is the case, why would fluid leak into the power booster from only the front reservoir?
I am trying to exhaust all the possibilities.
Old May 23, 2010 | 12:35 AM
Riderman's Avatar
Riderman
This may be normal. The front resivoir of the MC is usually for the front brakes, in this case, your calipers. You stated you have driven this truck for a year. Depending on several factor's, city driving, cheap organic pad's, (they wear faster) etc, this may be normal wear for the pads and the calipers did their job and needed the fluid to take up the slack, so to speak.
Old May 23, 2010 | 06:12 AM
miottimouse's Avatar
miottimouse
if nothing leaking visably i would pull the rear drums and check that area
Old May 23, 2010 | 07:34 AM
BSCowboy's Avatar
BSCowboy
Alright folks, thanks for the advice.
BigBlockF350
56
Apr 2, 2013 05:55 PM
i-w
13
Aug 26, 2010 07:48 PM
todd jo
Jun 30, 2009 08:08 PM
csangster
Sep 1, 2008 10:27 AM
jack83
Dec 10, 1999 04:01 PM
