Brake Pedal differences?
Old May 21, 2010 | 12:38 PM
Shane in WI's Avatar
Shane in WI
I have a 77 F100 2wd 3 speed manual front disc brakes.
I hava 75 F100 2wd automatic parts truck with power front disc brakes.
I remember reading that Ford made 21 different brake pedals for these trucks. Last night I pulled the pedal out of the parts truck. Other than a slightly different bend for pedal placement, they appear the same.
What is the difference? Is there slight difference in the hole placement where the arm bolts to the master cyl? One is an auto and the other a manual. My truck stops just fine with manual brakes, but wondered what it would take to add the option.
If I add power brakes to my truck, I know the booster, master cyl, proportioning valve need replacing, but what about the pedal?
I haven't pulled the pedal out of my truck to directly compare yet.
Thanks,
Shane
Old May 21, 2010 | 12:48 PM
hp246's Avatar
hp246
I think much of the difference is in the pedal rod.
Old May 21, 2010 | 04:11 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Shane in WI
You will want to use the ( power pedal ) they are made so the pedal swing is closer to the floor !
With the pedal mounted closer to the floor , you don't have to lift your leg / foot as high , sure makes it nice to drive !
The manual pedal sits as high as a clutch pedal .
P.s. I have always liked the manual brakes on the 73-79 trucks ,they work great !
Wally Womack
Old May 21, 2010 | 04:38 PM
Shane in WI
That's kind of what I thought. Since I am going from an automatic pedal to a manual brake pedal, I assume there may be differences there as well. I did some searching and learned there were many different clutch pedals, brake pedals and brake boosters used in these trucks. I may try to sell the power brake setup and not worry about it. Was just thinking ahead as the pedals appeared to be similar. Thank,
MavSprint
Feb 3, 2013 04:11 PM
MavSprint
Nov 9, 2012 07:35 AM
jxnslotcar
Sep 11, 2012 04:14 PM
Shane in WI
Sep 28, 2009 12:14 AM
kashmir432
21
Jun 24, 2009 11:43 AM
